Regrading Around House - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-19-2011, 03:48 PM   #1
regrading around house
hey guys, just about to start regrading and need some advice.
we've got a relatively flat lot sloping out to the street ever so slightly, and this wouldn't be a problem, but since the dirt is pretty much right up against our siding, I want to dig down some to expose the foundation about 8" (some of the wood is exposed and I want to prevent any rot and insects from getting in there).
i've heard others talk about gravel and clay and compacting, etc, but i'm uncertain. i've got the idea that everything would pretty much work out if I dug around the perimiter of the house and threw dirt out to lower elevations, minding the slope.
am i missing something? love to hear anyone else's experience doing something similar. thanks!
eddytheflow is offline   Reply With Quote
Old 06-20-2011, 07:14 AM   #2
Rewards Points: 1,492
and this wouldn't be a problem but since the dirt is pretty much wood is
uncertain. I've got the idea the everything would pretty much work slope.
am i missing anything? love to hear anyone else's experience doing something
similar. thanks!
First order of business, excavate around the house so the dirt does not touch
the wood siding. It is possible that immediately you run into a problem that
the rain water no longer flows out to the street.
Then you would need to regrade all the way from the foundation out halfway
to the street so water will flow away from the house. Or maybe all the way
to the street so the water collects out at your front property line.
Another idea is to dig a 1 foot wide by 1 foot deep trench all the way along
the foundation. Line the trench with seamless plastic sheeting end to end
with the sheeting coming up to surface level (U cross section) and adhered
to the foundation along that side. This will reduce water going down the
foundation. Fill the trench with gravel. The top of the gravel also needs to be
below the start of the wood siding by a few inches or so. Continue the
trench past the foundation by several feet at both ends and dig dry wells.
(The dry wells should not be against the foundation hence the need to
extend the trench.) It may be necessary to put a sump pump in each dry well
to send the water some distance from the house.
You will also need an underground perimeter drain system at basement
footing level since some of the water in the vicinity will go directly down
against the foundation as opposed to go to the side, to one dry well or the
other.
You should have a roof gutter along the front of the house so all the roof
water does not come down right in front of the house. The downspouts
should also not dump the water against the foundation.
Old 06-20-2011, 11:09 AM   #3
thanks allan, the gravel leading to a drywell is exactly the sort of thing i was curious about and might end up doing that as a last resort.
i do plan on installing a french drain on one side of the house where water does seep into the basement.
i planned on a "simple" regrading type of project, primarily for the purpose of raising the foundation height, so that dirt isn't touching any wood parts of my house. i didn't initially plan on installing a perimeter drain system below the foundation because water doesn't seem to seep in in large amounts.
if it ain't broke..?
i guess a concrete skirt wouldn't really help all that much either..
Old 06-20-2011, 11:48 AM   #4
A concrete skirt should also be a few inches below the wood. You don't want a driving rain to hit the more or
less horizontal top of the skirt and splasn on the wood just above.
Old 06-21-2011, 08:56 AM   #5
i'm thinking a concrete skirt might not be right for me.
while doing some searching i found this article which explains what i think i might end up doing.
http://doverprojects.blogspot.com/20...in-design.html
not exactly the french drain design that i'll use for my backyard (which also floods), and i'm not going to replace my gutters with this, but i think that overall it may help prevent moisture in my basement/crawlspace.
i think, anyways.
plus it just seems like something to do while i'm at it, digging around the perimeter of the house already.
eh?
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 07:18 PM
My house progress so far - over the years Snav Project Showcase 5 05-06-2015 11:11 AM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
