Regrade Or French Drain - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-23-2010, 07:47 AM   #1
Regrade or French drain
Not sure what to do in our backyard. We have a neighbor behind us that has a small hill and another on the side that has his gutter drain facing our yard. Our yard has some areas that are not completely flat. When it rains hard the water stands in the back and one side for days. Do we have to regrade the entire yard and then install a french drain or can we just install french drains on those two sides? Also is it difficult to regrade on your own??? Help!!!
Keeta is offline   Reply With Quote
Old 03-23-2010, 08:13 AM   #2
Rewards Points: 1,512
Where do you want the water to ultimately go?
French drains are supposed to collect the water and channel it somewhere, such as to a dry well or to a pit where a sump pump is placed. Or to a driveway if an appropriate pitch including out to the street can be achieved.
French drains are not supposed to absorb water, although they may absorb small quantities over a long period of dry weather.
AllanJ is online now   Reply With Quote
Old 03-23-2010, 03:50 PM   #3
GardenConcepts's Avatar
Rewards Points: 150
Adjusting the grade is the best solution- then install the french drain if still needed.
You can check for low and high spots with a few stakes and a string line. Cut and fill as necessary.
GardenConcepts is offline   Reply With Quote
Do I need to waterproof my basement if I already have a french drain? buratti Building & Construction 4 03-20-2010 03:32 PM
Berm and/or French Drain Solution?? (Pictures Included) appleman01 Landscaping & Lawn Care 9 03-20-2010 09:37 AM
creating a french drain ks2 Building & Construction 2 03-07-2009 12:15 PM
French Drain Solution? Any Help Would Be Great! gregt848 General DIY Discussions 2 08-01-2008 09:16 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
