Red Wall Brick As Ground Paver In The Yard? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-06-2011, 10:35 PM   #1
hohadcr's Avatar
Rewards Points: 306
Question
red wall brick as ground paver in the yard?
new to landscaping.
I want to add an area with pathway in the yard with pavement. I have abundant old red bricks (approx. 3"x7"x2") that are normall used for walls.
1. Can I use them for ground pavement?
2. If I can use red bricks, do I put gravel under and between them or sand?
3. If I can't use red bricks, is it better to use ready-made pavers or the faux stones with cement and molds to make them? Given this is DIY job and I don't have much experience with landscaping, but still want to make it economical.
hohadcr is offline   Reply With Quote
Old 08-08-2011, 07:59 AM   #2
hohadcr's Avatar
Rewards Points: 306
nobody knows????
Old 08-08-2011, 09:33 AM   #3
A Little Of Everything
Rewards Points: 1,356
Originally Posted by hohadcr View Post
new to landscaping.
Sure, you can use the bricks for pavers. The end result you want is going to determine how you place them.
If you want the pathway to look nice, you'll need to dig down, pour and pack a good level substrate, then add sand, then put down the bricks, then pour fine sand on top of them and broom it down between the bricks.
If you just want something that's a sort of pathway, you can lay the bricks right down on top of the grass. They'll work their way "down" and the grass will grow up around them. This would be very easy, but I would not recommend it.
DrHicks is offline   Reply With Quote
Old 08-08-2011, 10:59 AM   #4
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Sure you can use them. My front walkway is made from them and it's been there since 1930.
CoconutPete is offline   Reply With Quote
Old 08-08-2011, 11:47 AM   #5
Rewards Points: 87
You can use plain old construction bricks for pavers, but how well they hold up in a freeze/thaw environment is questionable.
You'll want to dig down several inches and slightly wider than the proposed walkway. Put down at least 4-5" of crushed stone, 2" at a time, compacting it with each layer, getting it approximately level. Then at least 2-3" of slag sand, which is what you'll finally compact and level. Lay your bricks, then add your border. The border can be either a concrete "curb," which comes only about half-way to the top of the bricks and will eventually be covered by grass (which will need constant attention due to the lack of soil under it), or a plastic barrier held in place by long spikes. Then you'll spread slag sand atop the bricks and broom it into place. Water. Let dry. More slag sand. Water. Let dry. More slag sand... until the spaces between the bricks stay filled.
A note about the concrete curb vs. the plastic barrier with spikes: The concrete curb, if done correctly, will hold the walkway's shape better, by far. The plastic barrier is easier, but will undoubtedly lead to increased maintenance, particularly if the walkway or patio is on a grade.
Learned all this by doing it myself, and getting it wrong, watching professionals do it, and them getting it right, and reading.
More Power! is offline   Reply With Quote
Old 08-08-2011, 02:58 PM   #6
Not a whole lot to add to the above post but they also make an aluminum edge for your pavers which in my opinion would be a the most cost effective solution although concrete really is the most stable and permanent solution but for most people its out of the realm of diy
CountryCare is offline   Reply With Quote
Old 08-09-2011, 09:02 AM   #7
hohadcr's Avatar
Rewards Points: 306
Thank you all, guys!! Probably start digging tomorrow.
Can Ground Water Wick Up A Foundation Wall? 99bobster99 Building & Construction 63 06-30-2012 07:21 AM
how to make white mortar for brick wall nhertel Building & Construction 2 05-26-2009 09:22 AM
Best way to cover over brick wall in basement? tigereye Remodeling 4 04-14-2009 11:24 PM
exposed brick wall Jrr1099 Carpentry 1 03-25-2008 03:45 PM
Exterior brick wall has cracks and moves...is this a huge problem? ConstantChange Building & Construction 3 06-16-2006 10:09 AM
