Originally Posted by Piper1
Based on this, is it safe to dig out under the exisiting driveway (approx. 1 foot) and replace the dirt with crushed rock to ensure better drainage? My fear is that the driveway may cave with a less solid base.
Definitely do not take anything out from under the driveway! It would be virtually impossible to compact anything he replaced it with sufficiently. It would just let the driveway deteriorate quite rapidly and cave in.
If I don't do this and build the retaining wall wider than it currently is I am trying to think how I can tie it into the driveway and still make it look nice.
All suggestions are welcome.
In my opinion your best bet would be to replace the existing retaining walls with new concrete ones. Remove the existing wood and dig a couple of post holes 3on each side to give good support. Then place your forms on three sides, leaving the side towards the driveway to be self forming against the remaining dirt that was behind the wood. I would make the concrete retaining walls 8"-12" depending on your preferences. Doing it this way would certainly be a lot more work and expense than some other options but would certainly provide a long-term solution!
You may also want to verify that the existing pipe under your driveway is in good condition because now I would certainly be the best time to replace it is necessary.
