Re Leveling Paving - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 12-22-2011, 05:46 AM   #1
Re leveling paving
Hi I had a blue stone patio laid a year ago. The pavers were laid on road base and a thick layer of cement/concrete or the pavers are cemented down. As I've started using the garden I've noticed that the patio was not laid properly, it is not level.
I would like to know if this can be fixed without ruining the pavers?
Charmain is offline   Reply With Quote
Old 12-22-2011, 06:11 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 608
Ayuh,... How far, 'n how so is it unlevel,..??
It really shouldn't be dead level,...
It needs abit of pitch to drain water...
The Following User Says Thank You to Bondo For This Useful Post:
Charmain (12-22-2011)
Old 12-22-2011, 06:27 AM   #3
Yes understand that there should be pitch, but this seems like a lot. It is gradual goes from 0in to around 3in, when you look at the BBQ and garden table they on a slant?
Old 12-22-2011, 08:15 AM   #4
natwlsn's Avatar
Slanted furniture will drive you crazy...
Was this professionally done? If so, have you contacted them? They should guarantee their work, or at least offer to why it is so uneven
natwlsn is offline   Reply With Quote
Old 12-22-2011, 08:38 AM   #5
Bondo's Avatar
Rewards Points: 608
Ayuh,... Is that over a 3' run, or a 30' run,..??
If you want to, just shim the BBQ, 'n table to nearer level...
Old 12-22-2011, 08:57 AM   #6
My garden runs along the side of my house and is on a corner lot, which means the garden is in section. The back of the garden which houses the washing line this part of the patio is level so I could certainly move the BBQ there but would not be pratical also it's not a very nice area or just a plain space to hang washing.
Half way down the side of the house is when the paving starts to slop and this is the nice part of the garden, when I say it's a gradual slop this is within a 3m area, so dose not matter where I put stuff it will still be on a slant.
Looks like I will have to get seating and a table made to counteract the slop?
Old 12-22-2011, 09:31 AM   #7
Bondo's Avatar
Rewards Points: 608
Ayuh,... Or as I said before,... Shim their legs to level them...
starting floor project with clean slate by using leveling compound robismyname Flooring 1 10-07-2011 01:53 PM
Drywall or studs first before self leveling cement sandoy1121 Flooring 0 07-26-2010 07:50 PM
self leveling cement questions gramps416 Flooring 0 07-05-2010 10:36 PM
floor leveling compound geraldS Flooring 4 03-01-2009 09:20 AM
Portland based self leveling underlayment under travertine floors Keith Carlson Ceramic Flooring 7 01-25-2009 04:58 PM
