Re-grading Around Brick Crawlspace - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-25-2011, 02:45 AM   #1
re-grading around brick crawlspace
Hello, I know that the grade should drop 6" within 10' but where should the grade begin? I have the driest crawlspace in the world (so why "screw it up", I know) but I have other issues (topsoil washing out, gully for driveway) so I'm going to start with re-grading around the house. Okay, in my crawlspace the dirt barely covers the concrete footings (maybe a brick deep tops). All around the outside of the crawlspace is backfilled one brick level above the inside, so basically the grade around the house is about 2 2/3" higher than the crawlspace. Should I just begin there, so the final grade at 10' will be about 3 1/3" below crawlspace grade, or is there some rule about that I should know. Thanks for your replies.
NCgranny is offline   Reply With Quote
Old 10-29-2011, 06:21 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,346
Ayuh,... At the foundation of course...
If it's pitched away from the house now, why mess with it...
Old 11-05-2011, 03:05 PM   #3
The grade slopes towards the house, not away...
The grade slopes towards the house, not away, so I don't know where you got that. Anyhow, I discovered that (unless you plan to treat your crawlspace like a basement with waterproofing, drains, etc.) the outside grade should start below the inside grade (the very definition, in fact, of "a dry crawlspace") and that the dirt crawlspace floor should be below joists, etc. by so many inches per code. That makes sense, but I was hoping to avoid chopping down a 40 y/o Christmas Tree on the ridgeline that is well above what the grade should be to eliminate a swale in the front yard. I guess I should cut it down and terrace the slope it's holding on the other side down towards the culvert?
TV Mount onto Brick Fireplace- Brick Integrity? andrew.volkart Building & Construction 4 03-01-2011 07:21 PM
Started Exposed Brick Wall, Studs within brick, should I stop? perry167 Building & Construction 4 01-05-2011 09:41 AM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
Sealing historic brick tenzo General DIY Discussions 2 11-22-2008 03:04 PM
crawlspace exposed to outside and damp djbauda Building & Construction 5 07-30-2007 07:49 AM
