Ratio Bleach To Water Cleaning Concrete - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-23-2013, 06:47 AM   #1
Rewards Points: 2,166
ratio bleach to water cleaning concrete
I've read many different ratios of bleach to water to clean concrete. My sidewalk is getting dark from mildew, common here in the south. What is a safe ratio that will do the least damage to adjoining grass?
Startingover is offline   Reply With Quote
Old 10-23-2013, 07:48 AM   #2
Rewards Points: 13,750
Startingover (10-23-2013)
Old 10-23-2013, 09:24 AM   #3
Rewards Points: 1,596
Bleach is now coming in higher concentration bottles than before; like double.
I'd pressure wash it without using any bleach or other chemicals if you can.
bob22 is offline   Reply With Quote
The Following 2 Users Say Thank You to bob22 For This Useful Post:
concretemasonry (10-23-2013), Startingover (10-23-2013)
Old 10-23-2013, 11:05 AM   #4
bob, I did rent a heavy duty pressure washer last summer and it wasn't very convenient, but the drive, patio and walks hadn't been cleaned in many years prior to me buying this house.
The bleach spray is for between times and what everyone around here uses. thanks.
Old 10-23-2013, 12:08 PM   #5
Rewards Points: 3,630
Use oxygenated bleach to keep from harming your grass or plants,chlorine bleach will kill any plant.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
Old 10-23-2013, 12:21 PM   #6
canarywood, where do I buy it around here?
Old 10-23-2013, 02:17 PM   #7
You may be able to buy it at Home Depot or Lowes,maybe even at Publix,or just google oxygen bleach.
http://www.oxygenbleach.com/what-is-...each.html#more
Old 10-23-2013, 07:44 PM   #8
MarginallyQualified
Rewards Points: 2,464
Rent a "floor machine" scrubber for the concrete surface.
The Following User Says Thank You to TarheelTerp For This Useful Post:
Startingover (10-24-2013)
Old 10-25-2013, 11:11 AM   #9
I found 'OUTDOOR' bleach today at H.D. and instructions for various uses.
thanks everyone
Old 10-25-2013, 11:15 AM   #10
Let us know how it works if you can remember to do so.
The Following User Says Thank You to bob22 For This Useful Post:
Startingover (10-25-2013)
Old 10-29-2013, 10:37 AM   #11
Used the 'outdoor' bleach today on the front walk. Instructions were lacking other than ratio to mix.
At first it didn't seem to be working. I let it set half an hr and went back and am pleased with results for so little effort. It didn't say to rinse but I didn't want to take a chance on footprints, inside on the carpet, so rinsed it off plus didn't think it'd be good for the concrete.
I used half the gallon in my sprayer so I'll need a lot more to do the drive, the sidewalk around the house and back patio.
Yes, unless I find something else, I'll use it again.
The Following User Says Thank You to Startingover For This Useful Post:
bob22 (10-29-2013)
Old 11-03-2013, 05:10 PM   #12
RETRACTING my praise of the Outdoor Bleach.
Yes, it worked on the front sidewalk which looked fairly nice to begin with.
Today used it on a side patio area which was black. This patio has been neglected by me the 1.5 yrs I lived here and undoubtedly for yrs before. It barely did anything. It cleaned it up slightly in splotchy areas and now it looks a mess.
Will not buy it again.
Old 11-03-2013, 05:36 PM   #13
kwikfishron's Avatar
Rewards Points: 618
Put a pressure washer on your Christmas list. If you owned one you know you'd be using it often. You wouldn't necessarily need one that was the size you rented.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Startingover (11-03-2013)
Old 11-03-2013, 06:24 PM   #14
LOL,
Good memory! My xmas list is getting pretty long. Funny, all the tools you need when you own a house.............
Old 11-03-2013, 07:17 PM   #15
If it was as bad as you say you should have adjusted the concentration or went full strength,or used chlorine bleach.
Forgot to say,you do know that black stuff is algae right??
Startingover (11-04-2013)
Help! Yellow Hot Water mechetti Plumbing 1 11-01-2012 08:57 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 04:48 PM
