Raising Property Level With Existing Lawn - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 01-21-2010, 01:54 PM   #1
Raising property level with existing lawn
This is probably a really dumb question but here goes ...
My property lies about 1/2 a foot below my right neighbor. Also, the grading sucks, plain and simple. So I want to raise the property level and have a nice positive grade away from the house into the woods. I'm going to lay down a drain tile on the left side of the property so excess water does not flood that neighbor since he is sitting about 1/2 a foot below me.
My question is: Do I need to have my lawn removed before adding soil to elevate the property? (I am not going to be putting a new lawn in per se, rather, various gardens and paths with sporadic "clearings with a little lawn).
What would be the drawbacks of just grading new soil over an existing lawn?
Thanks in advance and cheers all!
earthad1 is offline   Reply With Quote
Old 01-21-2010, 03:18 PM   #2
No need to dig up the lawn
But if you are putting gardens in then you will likely want to remove the grass
You do need at least 6" between the dirt & wood at the house
So keep that in mind for grading
Old 01-22-2010, 06:59 AM   #3
Thanks Scuba_Dave
Do you mean 6" between the dirt and where the siding starts? I'd like to keep at least 6" of foundation exposed and just seal it with that special paint you can buy.
Yea, wherever I choose to make raised bed or berms, I'll dig out an outline by removing the lawn.
This brings up another point. Once I do a rough grade, make sure its positive, do my final grading and all is good, I essentially have built a "canvas" to work with. If I start placing raised beds, gardens, berms, ect... won't this just mess up the grading all over again? I know they say to have the grading drop 1 foot for every 50 feet. I only have 60 feet to work with so should I be weary of creating too many beds? Or will drainage still occur properly?
Thanks again.
Old 01-22-2010, 09:24 AM   #4
Yes, 6" of foundation before wood
I only worry about grading right near the house
Most of my lawn is already sloped, front is fairly flat
Gardens could be slightly raised, fairly common
Do you currently have any standing water on the property after heavy rains ?
Old 01-22-2010, 10:34 AM   #5
I only worry abourt grading right near the house
I've never had any standing water in the front with heavy rains.
The backyard has substantial standing water during heavy rains. more so away from the house but its a problem overall.
Old 01-26-2010, 02:04 AM   #6
Exotic NooB
The berms you create for the raised beds... you might consider using an edging or pavers to prevent the grrass from creeping in and taking the berm over. It saves work anyway.
You also might benefit from using a stringline and a stringline level to find out about where your standing water spots are... Then you could use a flatnose shovel to peel and roll back the sod/lawn and drop in and level out the soil addition... and then put the sod on top of your new graded area. (It's a lot of labor.)
inlikeflint is offline   Reply With Quote
Old 02-08-2010, 07:51 AM   #7
Thanks for the tip...
Old 02-09-2010, 04:09 AM   #8
Too Short? Cut it Again!
Might want to look at a plat for all the properties around you. And I would get a civil engineer out to figure out the changes you should and can make. Your municipality may provide a free or cheap consult to get you started. While your solution may not effect your immediate neighbor, raising and sloping the grade six inches and then also rapidly draining off the water (would not be allowed to do so where I was in Central Illinois without filing a grading plan and getting permits. A community notice would probably have to be served as well) is going to have to effect something or somebody "downstream" of it. I would hate to see you slapped with EPA fines or a lawsuit later on down the road.
Where are you by the way? Could you please click on your username next time you are signed in and update your basic location?
Old 02-23-2010, 10:43 AM   #9
You could just dress the lawn with sharp sand over the next couple of years. This will improve drainage, raise the lawn and help the grass roots get deeper, which also means it does better in the summer or when its dry. Most golf courses in the UK dress the lawns with sand every spring and autumn.
PeterRegent is offline   Reply With Quote
Old 03-29-2010, 01:53 PM   #10
Thanks, I'll keep that in mind...Is that the term I should be looking for at the Hardware Store? Sharp Sand?
Raising step down living room questions phil. Building & Construction 10 02-05-2015 11:39 PM
Planting grass after tilling existing lawn werc Landscaping & Lawn Care 1 05-22-2008 01:38 AM
how to level existing hardwoods before carpet lucyperry Flooring 6 01-25-2008 05:40 AM
Raising existing walls of a garage ok2rvtravel Remodeling 3 10-09-2007 11:45 AM
