Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 10-04-2011, 01:03 PM   #1
Raising my lawn
My lawn is about 6 inches lower than my concrete patio. I don't like how deep it is. I'd like lay some dirt, then reseed/resod the grass. Do I have to remove the old grass before laying down the new soil?
edta1 is offline   Reply With Quote
Old 10-04-2011, 06:00 PM   #2
Raising my lawn
Assuming that it won't mess up your grade (i.e. cause water to run toward your foundation), then there is no problem with this. I'd probably give it a quick low mow beforehand to keep it from trapping air pockets when you bury it, but otherwise just pile it on.
Thunder Chicken is offline   Reply With Quote
Old 10-12-2011, 05:27 PM   #3
sdsester's Avatar
Raising my lawn
Only real danger other than mentioned would be if your existing sod is growing in some heavy clay or something. You could form a layer that would trap water and rot the roots on your new lawn. Ideally you should cut it out or till it over with the new soil you add.
sdsester is offline   Reply With Quote
What the hell happened to my lawn? (also: reseeding when weeds are present. N.Y.) Deck Landscaping & Lawn Care 14 05-24-2011 01:45 PM
Lawn Help garydigital Landscaping & Lawn Care 4 03-06-2011 04:36 PM
Trying to revive dead lawn... deevahs Landscaping & Lawn Care 2 05-13-2010 01:34 PM
Raising property level with existing lawn earthad1 Landscaping & Lawn Care 9 03-29-2010 02:53 PM
are the geese destroying my lawn? windowguy Landscaping & Lawn Care 17 04-16-2009 09:38 AM
