Raised Garden Next To House - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-26-2010, 03:18 PM   #1
Rewards Points: 358
raised garden next to house
can you make a raised garden next to a house? not directly on the house, but if I build a pressure treated box about 4" to 6" off the face of the house?
cbzdel is offline   Reply With Quote
Old 07-26-2010, 07:22 PM   #2
Gerry Petard's Avatar
I don't see the problem with that. What is your concern, specifically?
Gerry Petard is offline   Reply With Quote
Old 07-26-2010, 08:22 PM   #3
firehawkmph's Avatar
Rewards Points: 1,898
I don't think being close to the house is a problem, as long as you didn't already have a drainage problem to start with. I would consider using something besides treated lumber to frame it with, maybe cedar, redwood, or cypress. I don't like the idea of whatever is in the treated lumber leaching out where I am growing things to eat. Just my personal opinion.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 07-27-2010, 10:53 AM   #4
Rewards Points: 358
I was just concerned about moisture and maybe condensation on the siding, with possible mold and mildew problems... Just over thinking a simple projects
edit: good idea on the treated lumber to, I didnt think about that!
Old 07-27-2010, 12:17 PM   #5
I used PT on my raised garden
I then lined the inside with the old vinyl siding off the house
I have PT posts in my garden for support structure
CCA (has arsenic) is no longer made, new wood is ACQ & does not have arsenic
Certain national gardening publications have raised concerns about the safety of using treated lumber in food gardens. Pressure-treated lumber uses CCA (chromated copper arsenate) or ACA (ammoniacal copper arsenate) as a preservative. However, studies done by Texas A&M Agricultural Extension Service showed insignificant movement of these compounds into surrounding soil. Pressure-treated lumber has no proven effect on plant growth or food safety. However, on Feb.12, 2002, the U.S. Environmental Protection Agency (EPA) announced a voluntary decision by the lumber industry to move consumer use of treated lumber products away from a variety of pressure-treated wood that contains arsenic by Dec. 31, 2003, in favor of new, alternative wood preservatives. Alkaline cooper quaternary (ACQ) is a relatively new wood treatment that is available in some areas of the country. This product is higher in copper than CCA but is free of arsenic.
Old 07-27-2010, 01:32 PM   #6
Registered User
Rewards Points: 526
P.t. wood is not waterproof. Unless you buy it specifically treated for that--- with an extra cost. You are fine using the "ground contact, 40%retention" in dirt but remember not to water the plants as the p.t. will absorb water and rot, but not from insects or decay. Never entomb p.t. in concrete. A p.t. post in the ground will absorb water from the dirt by capillary action and adhesion. A tree feeds water to its leaves and fruit from its roots up through the trunk (think post). I would treat the p.t. with a waterproof liquid, especially the cuts and bare ends.
http://www.ufpi.com/literature/ptfaq-204.pdf
http://www.thompsonswaterseal.com/advice/faq.cfm
http://www.sciencebuddies.org/scienc...Bio_p033.shtml
Be safe, Gary
Old 07-27-2010, 03:49 PM   #7
Rewards Points: 358
got me thinking maybe I should try out a composite material... that would last forever right
Old 07-27-2010, 04:32 PM   #8
Like the composite decks that fall apart after 2 years ?
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
My new project, 31 year old house... Axhammer General DIY Discussions 3 04-08-2009 08:46 AM
