raised garden next to house
can you make a raised garden next to a house? not directly on the house, but if I build a pressure treated box about 4" to 6" off the face of the house?
I don't see the problem with that. What is your concern, specifically?
I don't think being close to the house is a problem, as long as you didn't already have a drainage problem to start with. I would consider using something besides treated lumber to frame it with, maybe cedar, redwood, or cypress. I don't like the idea of whatever is in the treated lumber leaching out where I am growing things to eat. Just my personal opinion.
Mike Hawkins:) |
I was just concerned about moisture and maybe condensation on the siding, with possible mold and mildew problems... Just over thinking a simple projects :laughing:
edit: good idea on the treated lumber to, I didnt think about that! |
I used PT on my raised garden
I then lined the inside with the old vinyl siding off the house I have PT posts in my garden for support structure CCA (has arsenic) is no longer made, new wood is ACQ & does not have arsenic Quote:
P.t. wood is not waterproof. Unless you buy it specifically treated for that--- with an extra cost. You are fine using the "ground contact, 40%retention" in dirt but remember not to water the plants as the p.t. will absorb water and rot, but not from insects or decay. Never entomb p.t. in concrete. A p.t. post in the ground will absorb water from the dirt by capillary action and adhesion. A tree feeds water to its leaves and fruit from its roots up through the trunk (think post). I would treat the p.t. with a waterproof liquid, especially the cuts and bare ends.
http://www.ufpi.com/literature/ptfaq-204.pdf http://www.thompsonswaterseal.com/advice/faq.cfm http://www.sciencebuddies.org/scienc...Bio_p033.shtml Be safe, Gary |
got me thinking maybe I should try out a composite material... that would last forever right :thumbup:
Like the composite decks that fall apart after 2 years ? :laughing:
| All times are GMT -4. The time now is 12:02 AM. |
