Rained On Unfinished Paver Job. - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 01-16-2012, 01:23 AM   #1
rained on unfinished paver job.
hi , i installed 900 sq ft. of pavers for patio, 6'' base and 1'' of sand ,
complete with concrete edge restraint all around, but didn't complete top layer of sand and compaction. got a little bit of rain and scrambled to cover but not enough tarp or plastic. my question is how long should i let dry out before sanding and compaction? am i ok?
thanks, danny
joaknuck is offline   Reply With Quote
Old 01-16-2012, 10:52 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,070
Ayuh,... It shouldn't hurt it any,...
The extra water helps with compaction...
Bondo is online now   Reply With Quote
Old 01-16-2012, 10:31 PM   #3
i pulled my tarps and plastic i put down and i saw that some of the pavers had settled on about 1/4'' half of my job, my concern is will it all level out when i vibraplate it down or do i have to peel up the whole section and re-sand and lay again?? professional opinion needed thanks...
Old 01-17-2012, 09:02 AM   #4
Rewards Points: 1,500
If the pavers don't level out by themselves, chance are you did not compact the sand bed enough.
While compacting the sand bed, did you soak it a few times between Vibraplate sessions?
Usually soaking it reduces the amount of mechanical compacting needed before you lay any of the pavers.
Rain is only a problem when it is heavy enough that the sand gets moved considerably (there is erosion).
Tags
pavers
Unfinished space - basement - what do I do? lfunk11 Insulation 4 10-13-2011 10:01 AM
What to install first: 8x8 post OR paver area cgilbert Landscaping & Lawn Care 1 03-18-2011 06:21 PM
Paver Sand and Blue/Grey Colored Bricks Curious123 General DIY Discussions 4 08-13-2009 08:22 PM
Paver install-hand tamper vs plate compactor bigboyjoel Landscaping & Lawn Care 9 07-23-2008 02:48 PM
