-   -   rained on unfinished paver job. (http://www.diychatroom.com/f16/rained-unfinished-paver-job-130171/)
joaknuck 01-16-2012 02:23 AM
hi , i installed 900 sq ft. of pavers for patio, 6'' base and 1'' of sand ,
complete with concrete edge restraint all around, but didn't complete top layer of sand and compaction. got a little bit of rain and scrambled to cover but not enough tarp or plastic. my question is how long should i let dry out before sanding and compaction? am i ok?
thanks, danny
Bondo 01-16-2012 11:52 AM
Ayuh,... It shouldn't hurt it any,...
The extra water helps with compaction...
joaknuck 01-16-2012 11:31 PM
i pulled my tarps and plastic i put down and i saw that some of the pavers had settled on about 1/4'' half of my job, my concern is will it all level out when i vibraplate it down or do i have to peel up the whole section and re-sand and lay again?? professional opinion needed thanks...
AllanJ 01-17-2012 10:02 AM
If the pavers don't level out by themselves, chance are you did not compact the sand bed enough.
While compacting the sand bed, did you soak it a few times between Vibraplate sessions?
Usually soaking it reduces the amount of mechanical compacting needed before you lay any of the pavers.
Rain is only a problem when it is heavy enough that the sand gets moved considerably (there is erosion).
