Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 03-19-2009, 04:18 PM   #1
Rain water management system
My driveway has a slight tilt down to the garage doors and during heavy rain water gets in the garage. Nothing major just not the best situation.
Did a little searching on the web and found a system you dig into the driveway in front of the doors that allows you to channel the water away.
http://www.acousa.com/homedrain/raindrain.htm
Anybody have any experience with these?
Live in CT and was wondering about freezing and any problem supporting the weight of cars.
Davidb6 is offline   Reply With Quote
Old 03-26-2009, 07:30 PM   #2
If you throw the water off to one side I've seen guys come in with comcrete cutters and put a 6" wide 1"-2" deep trench in front of the door and then you drop in a steel or aluimiun grate. You just need to have the grate before hand so you're sure of you dimensions
Dugger52 is offline   Reply With Quote
Old 03-26-2009, 07:42 PM   #3
Concrete & Masonry
Wait until you see a price for that trench drain!
jomama45 is offline   Reply With Quote
Old 03-26-2009, 07:58 PM   #4
That's why I recommeded the cut. How much is that in per foot. It's got to be cheaper than that system.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 11:24 AM
boiler / Over-pressurizing cparke HVAC 1 05-21-2008 06:54 AM
Rain water draining into sump pit ERIK2173 Building & Construction 19 07-20-2007 10:19 PM
