Rain barrel pump?
gjones, yo really need to overseed this fall with drought resistant grass. As for your situation, you could go to Ace or Lowe's, and get a pump that you drop in when wanting to water, and remove when done. As for the amount you have available. what ever the level is that you have in there, if it is not a full 55 gallon's, it will not last that long to give your grass a good drink.
How much square footage are we talking about, for the yard you want to water? Keep in mind, that if there is no rain, you are just pretty much like a guy in the desert holding a sieve to collect water.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
