Railroad Ties- How To Install Or Anchor? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-01-2009, 12:05 PM   #1
Railroad Ties- How to install or anchor?
I plan on using some railroad ties as a border for a gravel parking area. The space will be graded and then new gravel will be spread. How do I go about "installing" or anchoring the railroad ties? Drive a large spike through them?
Also, any reason I shouldn't use railroad ties? I've read that they are soaked in a nasty chemical. Is it that bad?
ta845 is offline   Reply With Quote
Old 04-01-2009, 01:57 PM   #2
Remodeling Contractor
If you have a good cheap source use them. Drill a hole trough and drive a spike made for these. It is a galvanized nail about 12- 18" long
Old 04-01-2009, 04:12 PM   #3
kimberland30's Avatar
Since you are just using gravel, railroad ties will be fine. They aren't so good if you are using them for a landscape or flower garden border.
Just as the OP stated, drill holes in them and drive stakes through. However, unless your ties are perfectly level (which most aren't) and you stake them at an angle, they will come up pretty easily. I just redid our flower bed last year and the old ties came up with no problem.
I used a similar product (untreated since it was for a flower bed) and I buried the first row (drilling every foot and staked them slanted so that they didn't come out), then compacted soil on each side so it would stay put. Then I laid on another row on top, using 8" x 1/2" and a hammer drill to screw the top row to the bottom row.
So far it hasn't moved, which could be a bad thing since we are moving our sidewalk and I need to make that flowerbed smaller.
kimberland30 is offline   Reply With Quote
Old 04-01-2009, 07:52 PM   #4
Rewards Points: 1,578
You might want to buy rebar (stuff that goes into concrete to make it stronger) and use that; likely less expensive than 12" nails. Just buy some 3/8" or 1/2" rebar and cut it with hacksaw, drill pilot hole, and pound it in.
bob22 is offline   Reply With Quote
Old 04-01-2009, 08:22 PM   #5
Rewards Points: 150
conduit works good, cheap as well.
johnnyboy is offline   Reply With Quote
Diagonal Hardwood Install Advice JDeFuria Flooring 7 06-29-2009 03:35 PM
Railroad fcmazz Building & Construction 13 04-10-2009 06:06 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
Railroad Ties Wall & Black Widow Spiders Dona Pest Control 4 09-06-2008 04:04 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
