PVC Sprinkler Leak At T Joint - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-22-2010, 10:59 PM   #1
PVC Sprinkler Leak at T Joint
My PVC sprinkler system has a T joint at a certain point.
Water has begin to leak out of one of the ends of the T joint. There are no cracks in the pipe, it just leaks out of the T joint over the pipe going into the joint.
I tried putting some PVC glue/cement around that joint but the water still is breaking through.
Is there any way I can seal off this leak without replacing the T joint which would mean cutting apart three different pipe lines?
Is there some kind of combination of glue / cement and a certain tape that will keep the joint from leaking?
Thanks.
D2D2 is offline   Reply With Quote
Old 08-23-2010, 07:03 PM   #2
Don't know it all, yet!
No, nothing short of replacing the joint will solve the leak, unless you believe the TV ads for some kind of miracle putty. However, there is an excellent fitting for only a couple of dollars. It is called an EZ span T. EZ span makes couplings that extend with an O-ring for replacing inline leaks. Simply push the ends toward the center about 1 1/2 inches (in a closed position if you will), measure how much you need to cut out of the damaged pipe then glue and extend the ends of the EZ span over the old pipe somewhat like an old fashioned radio antenna. A couple of years ago they came out with these Ts and they are a lifesaver for repairs at a T in the middle of a run.
BTW- they are only a couple of dollars, maybe three.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 08-25-2010, 02:20 AM   #3
Thank you for your response. Do you know where I could locate this EZ Span Tee online? I've tried searching Google but all I've seen is the EZ Span coupler.
Old 08-26-2010, 04:57 PM   #4
Sorry, don't know about an online source. Any plumbing supply near you should have one but might not find one at the big box stores.
Basement wall/floor joint leak fubar79 Building & Construction 13 03-19-2015 10:50 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
pvc drain pipe joint leak nytstyk Plumbing 2 12-28-2009 01:05 AM
water line joint leak dtzulu Plumbing 4 05-14-2009 10:18 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
