Putting In Patio - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-27-2008, 08:05 AM   #1
Question
Putting In Patio
I am going to put in a Patio that is 27' X 32' and I come up with 324 Paver's that are 22/3" T X 8" W X 4" D. I would like to know if I am right on the amount of Paver's that I will need?
What would be the best base to put them on?
Would one need to put drainage under the Patio?
Is there anything ele that I need to complate the job?
Crazy Legs is offline   Reply With Quote
Old 04-27-2008, 11:22 AM   #2
concretemasonry's Avatar
Rewards Points: 2,594
Go to the Interlocking Concrete Paveing Institute site (icpi.org) for instructions and tecnical information.
Use 6-8" of compacted level road base. - Same as under asphalt.
Use a 1" uncompacted, leveledclean concrete sand.
Set the pavers and install the edging (steel, aluminum, plastic, concrete).
Spread mason's sand and vibrate with a plate vibrator.
Sweep clean.
If you are concerned about surface drainage, slope the top of the compacted base and still use 1" of sand for a setting bed.
concretemasonry is offline   Reply With Quote
slumped patio fix ?? houser Building & Construction 5 03-18-2010 06:25 AM
Cement Patio Deteriorating..? DeepDish Building & Construction 6 05-09-2007 10:03 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 08:11 AM
Small Patio Leenders Landscaping & Lawn Care 4 06-23-2006 01:30 PM
