Pull Rope On Troy 4 Cycle Cultivator - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-16-2009, 11:08 AM   #1
Pull rope on Troy 4 cycle cultivator
The pull rope on my little cultivator is not engaging the starting clutch correctly. I'm trying to get to it so I can repair or replace. My problem is how do I get the spring loaded weights off the shaft so I can remove the plastic cover that holds the engaging clutch. I can't tell if it's screwed on or pressed on.
Any suggestions would be appreciated.
ole 66 is offline   Reply With Quote
Old 08-16-2009, 12:31 PM   #2
Kap
Mowing my life away.
Most MFRs will have parts diagrams on their websites. That might give you an indication.
Kap is offline   Reply With Quote
No Pull lube jamiedolan Electrical 7 12-16-2008 12:00 PM
