-   -   Pull rope on Troy 4 cycle cultivator (http://www.diychatroom.com/f16/pull-rope-troy-4-cycle-cultivator-50998/)
ole 66 08-16-2009 12:08 PM
The pull rope on my little cultivator is not engaging the starting clutch correctly. I'm trying to get to it so I can repair or replace. My problem is how do I get the spring loaded weights off the shaft so I can remove the plastic cover that holds the engaging clutch. I can't tell if it's screwed on or pressed on.
Any suggestions would be appreciated.
Kap 08-16-2009 01:31 PM
Most MFRs will have parts diagrams on their websites. That might give you an indication.
