Pruning Maple Trees - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-30-2010, 09:44 AM   #1
pruning maple trees
I have 2 maple trees in my front yard one has grown somewhat higher than the other and i was considering pruning it for height to make them look more alike. Anyone have any tips or suggestions on this. Thanks
trump is offline   Reply With Quote
Old 03-30-2010, 09:51 AM   #2
What kind of Maple trees ?
How tall are they ?
I have topped multiple Silver Maple trees that were growing too tall
They are hard to kill
I also have one that I trim back to 10-12' tall every year
Sort of an experiment in growing my own shade umbrella
Old 03-30-2010, 04:06 PM   #3
Not sure what type of maples they are I live in Southeast B.C. Canada right next to montana border. They ar 20-30 feet tall
Old 03-30-2010, 04:56 PM   #4
GardenConcepts's Avatar
Rewards Points: 150
I would suggest pruning in such a way as to maintain a central leader. If you only top the tree, you'll get multiple leaders coming out from the pruning cut, which doesn't look as nice and changes the natural shape of the tree. Once you cut the tree to height, select a new central leader, and if necessary, train the leader over the next few years by removing other lateral branches that try to compete for height.
GardenConcepts is offline   Reply With Quote
Old 04-02-2010, 04:03 PM   #5
fix it
Chris is right. You don't want them to look like the trees the power companies top that get too close to power lines...
detailedEye is offline   Reply With Quote
Old 04-05-2010, 10:42 AM   #6
Rewards Points: 152
Never heard of maples needing or desiring one central leader...maybe one that is SLIGHTLY taller than the others around it...but maples are often if not usually fairly rounded tops. Pines, firs, etc should have one leader....not maples though...as far as I know.
ETA: Timing is somewhat important...best to do it in the winter when dormant...may not be too late being how far north you are. OTOH...ok to prune them any time of year...just preferable in winter if possible.
piste is offline   Reply With Quote
Old 04-05-2010, 11:04 AM   #7
Learning by Doing
Leah Frances's Avatar
One tree is grown higher than the other because it has somewhat better light/water/whatever than the other. Unless you can (as in, "ARE ABLE") fix the differential you are going to have a constant battle to try and keep these trees matchy-matchy.
I have a pair of maples in front of my house (southern exposure) one gets morning light - and that little bit of extra makes it a fuller, taller tree. And, for me, it's more important to let nature do the work than try to prune the top of a 40 foot tall tree to keep them 'more alike'.
If I could only remember to THINK about what I was doing before I did it.
Last edited by Leah Frances; 04-05-2010 at 11:06 AM. Reason: funny spelling error exposer /= exposure
Leah Frances is offline   Reply With Quote
Old 04-05-2010, 11:37 AM   #8
Rewards Points: 150
There is nothing wrong with on tree being larger than the other- but if you want them to match, go ahead and prune the tree.
No tree 'needs' a central leader- but Maples, Oaks, Ash, Hickories, Pine,Fir, Spruce, etc, all exhibit 'apical dominance' and will produce a strong central leader when grown in their native habitat (the forest). When any tree is grown out in the open (suburban lawn) they tend to get wider, and will produce multiple leaders. Nothing is wrong with this if you like that look- I prefer a central leader.
Old 04-06-2010, 12:37 PM   #9
Rewards Points: 129
IIRC most maples should be pruned after leaf out in the spring. While most trees should be pruned while dormant, the same things that give the sap for maple syrup will create problems in there are open wounds when the sap begins to run. I would check with an arborist about your particular tree type.
ptarmigan61 is offline   Reply With Quote
What are some fast-growing trees? proofer Landscaping & Lawn Care 32 03-27-2009 01:00 PM
staining maple GregWCIL Painting 8 02-14-2009 09:37 AM
Maple..confused. Need Help!!!! SciFi2009 Flooring 2 12-25-2008 05:45 PM
Opinions on Boulevard Trees dgbehrends Landscaping & Lawn Care 4 10-11-2008 07:35 PM
pruning trees... joeyboy Landscaping & Lawn Care 7 06-02-2008 03:38 PM
