Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 03-16-2011, 09:39 AM   #1
pruning before spring
Well up here its starting to warm up a little bit, and the hedges and trees are looking a little ragged... no leaves on them yet or anything, is it a good idea to prune now? or should I wait for leaves? none of them are flowering plants
BlueBSH is offline   Reply With Quote
Old 03-16-2011, 10:35 AM   #2
Not an arborist, or anything close, but we have quite an assortment of trees, bushes, etc., on which we do a lot of trimming over the winter, with no adverse affects that I have ever seen. It's a good reason to be outdoors, you can see what you are doing better with the foliage out of the way, and I have always figured that the extra clothing that you need in cooler temperatures offers a bit more protection against poison ivy, etc. Hedges, as an example, I will usually trim just the larger limbs back, and wait until spring, when everything is coming to life again, to do more precise trimming. But, in the case of apple trees, I work my way from the center out every winter, nipping suckers, and removing any dead, diseased, or otherwise unwanted limbs. Some people leave ornamental grasses and things like that alone until spring, but we always cut those back in the fall or early winter, when we don't have to be as selective.
Old 03-18-2011, 12:52 AM   #3
You should always do your trimming late summer or early spring. Cold weather could hurt newly trimmed areas. Always trim when you see your plant, tree, or shrub growing and not when it's dormant.
KTBrewer is offline   Reply With Quote
Old 03-18-2011, 06:01 AM   #4
paper hanger and painter
chrisn's Avatar
yes
Old 03-18-2011, 06:04 AM   #5
chrisn's Avatar
[quote=KTBrewer;611727]You should always do your trimming late summer or early spring. Cold weather could hurt newly trimmed areas. Always trim when you see your plant, tree, or shrub growing and not when it's dormant.[/quote]
Not necessarily true, depends on what you are pruning. Most deciduous trees, dormant is the BEST time to prune
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 04:30 AM
Think Spring! LateralConcepts Landscaping & Lawn Care 0 03-09-2011 11:46 AM
Size of Garage Door Torsion Spring planet Carpentry 3 12-19-2010 04:29 PM
Garage Door Extension Spring Question kmc143 Building & Construction 4 02-23-2010 09:24 AM
Spring Hinges jb198606 General Discussion 3 02-06-2006 09:40 PM
