-   -   pruning before spring (http://www.diychatroom.com/f16/pruning-before-spring-98570/)
BlueBSH 03-16-2011 08:39 AM
Well up here its starting to warm up a little bit, and the hedges and trees are looking a little ragged... no leaves on them yet or anything, is it a good idea to prune now? or should I wait for leaves? none of them are flowering plants
DexterII 03-16-2011 09:35 AM
Not an arborist, or anything close, but we have quite an assortment of trees, bushes, etc., on which we do a lot of trimming over the winter, with no adverse affects that I have ever seen. It's a good reason to be outdoors, you can see what you are doing better with the foliage out of the way, and I have always figured that the extra clothing that you need in cooler temperatures offers a bit more protection against poison ivy, etc. Hedges, as an example, I will usually trim just the larger limbs back, and wait until spring, when everything is coming to life again, to do more precise trimming. But, in the case of apple trees, I work my way from the center out every winter, nipping suckers, and removing any dead, diseased, or otherwise unwanted limbs. Some people leave ornamental grasses and things like that alone until spring, but we always cut those back in the fall or early winter, when we don't have to be as selective.
KTBrewer 03-17-2011 11:52 PM
You should always do your trimming late summer or early spring. Cold weather could hurt newly trimmed areas. Always trim when you see your plant, tree, or shrub growing and not when it's dormant.
chrisn 03-18-2011 05:01 AM
yes:thumbsup:
chrisn 03-18-2011 05:04 AM
[quote=KTBrewer;611727]You should always do your trimming late summer or early spring. Cold weather could hurt newly trimmed areas. Always trim when you see your plant, tree, or shrub growing and not when it's dormant.[/quote]
Not necessarily true, depends on what you are pruning. Most deciduous trees, dormant is the BEST time to prune :yes:
