Protect Snow Thrower Scoop From Wear? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 01-07-2011, 03:36 PM   #1
Rewards Points: 894
Protect Snow Thrower scoop from wear?
Hi;
My snow thrower is only in it's 2nd season, but I am noticing some very light wear at the edge of the scoop. It's from hitting uneven sidewalks, etc and just normal wear. Unfortunately, much of the area I need to use the machine on is concrete, which is much harder on the scoop than asphalt is.
I am wondering if there is a strip of Teflon that I could get to place onto the scoop to protect it from such wear.
FW
Ultrarunner2017 is offline   Reply With Quote
Old 01-07-2011, 05:22 PM   #2
Rewards Points: 1,512
Teflon will not protect the bottom edge.
You need to select a slower forward speed.
Go too fast and the bottom edge catches on a crack or bump with a tremendous "THUNK", the snow blower bucks and bobs, and the bottom edge can get deformed.
Old 01-07-2011, 05:24 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,354
Ayuh,... You mean the cutting edge at the bottom,..??
It's a replaceable/ adjustable wear part...
If it's scrapping to much, adjust the front skis down abit, or the cutting edge up....
Bondo is online now   Reply With Quote
Old 01-07-2011, 05:26 PM   #4
Experienced
Jackofall1's Avatar
I did mine with UHMW, high strength plastic, sharpened on the bottom. But it is a wear item as mentioned.
Old 01-07-2011, 05:56 PM   #5
Rewards Points: 894
Hey, thanks for pointing out the fact that the shave plate is a replaceable part, as are the skid shoes.
I have been running the machine at the lowest speed on concrete, and any area where it tends to catch. I have found that a slight downward pressure is necessary on the handle to keep the machine from catching and bucking on concrete.
I have thought of raising the skid shoes slightly, but have not yet. They are at factory default setting.
The reason why I am hesitant to do so, is that I will then leave a film of snow/ice on the surface. But I suppose I should experiment.
FW
Old 01-07-2011, 06:18 PM   #6
Bondo's Avatar
Ayuh,... You Lower the skids, or Raise the cuttin' edge.....
Old 01-07-2011, 06:38 PM   #7
Rewards Points: 894
Sorry about that. I meant lowering the skid shoes. My bad.
Old 01-12-2011, 11:09 AM   #8
Rewards Points: 894
Hey, thanks guys, for advising me on lowering the skid shoes
I did it yesterday, and it snowed overnight. What a difference! No bucking on the concrete, and I was able to run as the 2nd notch instead of the 1st which I had been using pretty much exclusively.
In the instructions, there was a line that I had apparently completely missed during assembly. It said that the skid shoes had been put in the up position for shipping, and that they should be adjusted as necessary.
I am pissed at myself for having overlooked something so obvious. When the machine was bucking on the concrete, I just thought it was normal for that surface. I was getting around the problem by putting constant downward pressure on the handle, which basically caused the scoop to ride slightly higher and allow a smoother ride on the concrete.
Don't know what I thought the skid shoes were there for.
Funny thing is that I did read the instructions prior to assembling the machine. I guess I got distracted. But I really should have been able to figure out what was happening when it was bucking. Now, I have used the machine a total of six times, and, I think that had I not come here and posted about wear to the shave plate, I might have run it another five times before figuring this out.
I have to seriously re-think my thinking... like, re-program my brain??
If only I could plug myself into a USB port and get it all done. Then I wouldn't need to come on here and ask questions that sound so dumb
Thanks again
FW
Old 01-12-2011, 02:04 PM   #9
Bondo's Avatar
Ayuh,... Glad to hear it worked out for ya,....
'n Thank You for comin' back with the Update,...
Snow Thrower Gearbox siezed Ultrarunner2017 Landscaping & Lawn Care 8 03-08-2011 04:29 PM
ariens 724 snow thrower tileman95 General DIY Discussions 16 12-31-2010 03:45 PM
YTD Yard Machines 21" Snow Thrower auger shaft won't dissassemble Ed Bielefeldt Landscaping & Lawn Care 1 12-20-2010 07:45 PM
Craftsman snow thrower starter rope broke hdthoreau General DIY Discussions 1 12-07-2008 04:18 PM
Ariens Snow Thrower xavierarmadillo Tools 3 12-17-2007 03:47 PM
