Proper Paver Base For Patio? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-11-2013, 12:01 PM   #1
taniadiane's Avatar
Proper Paver Base for Patio?
Hello Group,
I am new to this app so if I am doing this wrong, I apologize!
We had a "sunken" patio area dug out from a landscaper. We have purchased the retaining wall blocks and are wanting to lay down pavers, as well. The area is quite small - approximately 10' x 10'.
When it rains, the area fills with water and does NOT drain. My question is, is there a special sand that helps with water absorption that we need to put down first, instead of regular sand?
Any advice would be greatly appreciated!
Tania
taniadiane is offline   Reply With Quote
Old 09-11-2013, 12:35 PM   #2
concretemasonry's Avatar
Rewards Points: 2,578
Your paver base (compacted road base) should be sloped in the direction of planned drainage. After compacting, screeding off any humps will give you a profle for finished grade. Then, just add a 1" uniform thickness of screeded uncompacted concrete sand setting bed. You can expect a 1/4" or so maximum settlement after the final vibration with a plate compacter to draw sand into the tight joints and true up the finished paver surface. Your edge restraint can be used as reference for the top of the finished paver surface and the smoothed out compacted base.
Do not try to control the surface elevation by adding sand, since with too much sand in some areas the pavers can "swim" if you get a lot of rain.
Dick
concretemasonry is offline   Reply With Quote
Using Concrete as Paver Base? Boiler98 Landscaping & Lawn Care 4 07-27-2012 11:09 AM
Paver patio/wall corrugated drain location BrandonC_1972 Landscaping & Lawn Care 0 07-05-2012 12:31 AM
HELP! Paver Base problem mytjojo Landscaping & Lawn Care 0 05-03-2011 06:41 PM
How much will road base compact? jbdkisner Landscaping & Lawn Care 2 02-04-2010 07:10 PM
Paver Patio Base Material fpr4 Landscaping & Lawn Care 2 06-17-2009 09:26 PM
