Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 08-26-2012, 07:46 PM   #1
Problem with the citrus tree
Attached are few pics of my two citrus shrubs. They seem to have an issue. Please see the photo. Some of the leaves are turning yellow.
I am sure they are getting enough water but I don't know what is the other reason for this problem. Can you please shed some light on this ?
http://i699.photobucket.com/albums/v...24-29-32PM.png
http://i699.photobucket.com/albums/v...1/P1010110.jpg
http://i699.photobucket.com/albums/v...1/P1010111.jpg
http://i699.photobucket.com/albums/v...1/P1010112.jpg
http://i699.photobucket.com/albums/v...1/P1010113.jpg
http://i699.photobucket.com/albums/v...1/P1010114.jpg
http://i699.photobucket.com/albums/v...1/P1010115.jpg
http://i699.photobucket.com/albums/v...1/P1010116.jpg
cprao is offline   Reply With Quote
Old 08-27-2012, 12:58 PM   #2
Looks like you have a leaf miner problem,and i forget the solution but any good nursery will have the cure.
Canarywood1 is offline   Reply With Quote
Old 08-27-2012, 08:55 PM   #3
Thank you for the hint.
Old 08-28-2012, 12:41 PM   #4
sdsester's Avatar
Looks like you have some sort of bug and insect infestation going on or trying to get a foothold.
Over watering can turn citrus leaves yellow too. They are also prone to a condition called chlorosis (if I remember the name correctly)---an iron deficiency---but this is usually characterized by yellow leaves with green veins.
Citrus are acid loving plants so test your soil. You can get a home Ph kit for $10-20 I should think.
If you have never done one, a complete site soil test can save you lots of money on plants, amendments, fertilizers, etc. over the years and they do not cost that much. Some states used to do them for free. Make sure to test the whole yard. Especially with new construction the topsoil is often scraped off to level for foundation work and never returned. Sometimes other soil is brought in to replace it or it is all stacked up in the backyard or hauled off. Point being you can end up with very different soil between your frontyard and backyard.
sdsester is offline   Reply With Quote
Problem with toilet (vent problem?) branch155 Plumbing 24 03-09-2012 10:37 AM
American Standard intermittent inducer problem with presssure switch warning no such user HVAC 5 12-26-2011 06:20 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
