Problem With Automatic Lawn Sprinklers - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 10-10-2013, 08:37 PM   #1
Flt_Simulation's Avatar
Problem with automatic lawn sprinklers
I live in Florida and am having a problem with my Rainbird automatic lawn sprinklers.
I haven't used the lawn sprinklers since last year do to all the summer rain we get here. Last winter all 7 zones worked perfectly.
Now zone 3 and 4 are not working. When they are supposed to come on, all I hear is a clicking / thumping sound about once each 2 seconds from the electric solenoid valves for both these zones ... but no water is coming out of the sprinkler heads for zone 3 and 4.
All I can think is that the little electric solenoid valve (one for each of the 2 zones) must be bad.
It's obviously getting power or these 2 valve would not be making that continual knocking sound.
Do I need to go buy new solonoids for these 2 zones? (again, all 7 zones worked perfectly last year).
Thanks,
Ron
Flt_Simulation is offline   Reply With Quote
Old 10-10-2013, 08:52 PM   #2
Rewards Points: 278
Sometimes it can be caused by a simple clog or buildup of sediment, which you can repair easily. Just unscrew the head and clean out any clogs with your fingers or a small tool.
You can check for a current at the zone wire terminal where the failure is located with a mm if you want to confirm it, then reset the controller. Additionally, you can check the electricity flow from the controller. As you have already stated, you may need to replace the controller or the valve solenoid.
jmon is offline   Reply With Quote
Old 10-10-2013, 10:02 PM   #3
Rewards Points: 34
Depending on your valves. Try opening the valve manually. On the rainbirds it's a matter of turning the solenoid.
Dan
djlandkpl is offline   Reply With Quote
Old 10-13-2013, 07:06 PM   #4
Thanks for the suggestions.
I just went to Home Depot and bought a replacement diaphragm and solenoid for the valve ... works perfectly now!
I first took the valve apart and cleaned it out real good, but that didn't help.
The Following User Says Thank You to Flt_Simulation For This Useful Post:
jmon (10-13-2013)
lawn tractor problem copseycliv Landscaping & Lawn Care 1 06-25-2011 10:32 AM
Trying to revive dead lawn... deevahs Landscaping & Lawn Care 2 05-13-2010 12:34 PM
Lawn sprinklers trying to fire when off sportinwla Landscaping & Lawn Care 2 03-25-2010 10:06 PM
Weed problem, bug problem, or both? hayzen Landscaping & Lawn Care 1 08-25-2009 06:33 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
