Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 06-21-2012, 08:32 PM   #1
privacy fence
I put in a picket fence in which I bought 8 foot sections; when I put in some of the posts, I didn't leave room for error and ended up with too much space between posts, sometimes up to 2 to 3 inches to deal with. This was ok for the picket fence sections, but now I want to put up a vinyl privacy fence by sections. How do I manage this without pulling out the fence posts and starting from scratch :0(
MNBluestater is offline   Reply With Quote
Old 06-22-2012, 08:41 AM   #2
privacy fence
If you don't want to redo it, I would use a long wood to wood tie plate, or a couple short ones, one from each fence section to the post, to attach it all together.
Similar to this: http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
Then buy a an extra picket or two to mount over the top and hide them.
Doing things almost the right way...
Double is offline   Reply With Quote
Old 06-22-2012, 11:33 AM   #3
biggles's Avatar
privacy fence
mount couplers on the exsisting post and slip the vinly horizontals pipe into the couplers and adjust then match the color you in
Old 07-15-2012, 07:19 PM   #4
The Fence Guy
TheFenceGuy's Avatar
privacy fence
Are your panels attached with brackets or do they fit into routered holes in the posts?
TheFenceGuy is offline   Reply With Quote
6' wood privacy fence questions snosurfa7 Landscaping & Lawn Care 13 06-01-2012 02:45 AM
Reuse Concrete Fence Post Pier & Fence Post Extraction JasonCA Landscaping & Lawn Care 2 03-24-2012 09:58 PM
Max Fence Height In LA For Pool Privacy ... JasonCA Building & Construction 7 05-09-2011 05:45 PM
Privacy Fence 4x4 Post against Garage? jpearson311 Building & Construction 8 05-19-2010 02:19 PM
A few questions about building a wooden privacy fence in Florida Tineras Building & Construction 4 03-22-2009 02:38 PM
