Pressure Washing Concrete - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-12-2009, 10:28 AM   #1
DIY = Done Right 1st Time
Pressure washing concrete
What can I use along with the water to clean off any loose paint, green matter, staining on my concrete steps? Looking to not layout a ton of money on fancy chemicals.
BowDown is offline   Reply With Quote
Old 05-12-2009, 07:51 PM   #2
Rewards Points: 1,520
You may not need any chemicals; try water alone and see if it comes off to your liking. If not, stores have lots of stuff to buy.
bob22 is offline   Reply With Quote
Old 05-12-2009, 07:58 PM   #3
I've been using just a power washer on my concrete pool deck
I think its a 2500 psi model - runs off gas
Old 05-13-2009, 10:21 AM   #4
Rewards Points: 346
Just water can work pretty good. For stains on concrete I have had good success using a cheap powered laundry detergent mixed with water to make a paste. I will scrub this on any stains then keep it wet by spraying it once in a while or cover it with a plastic tarp for a few hours. For green (alge or vegetation) stains mix a little bleach in. I have had stains from oak leaves that never went away... It must be something unique to that particular leaf.
Rege
Rege
RegeSullivan is offline   Reply With Quote
Old 05-13-2009, 06:37 PM   #5
Yeah, leaf stains are really tough. I think a bleach/chlorine solution strong enough to oxidize them will likely kill any plants nearby from runoff.
Old 05-14-2009, 11:13 AM   #6
Rewards Points: 346
It's the oak leaves that I could not get off with bleach or hydrogen peroxide (oxy clean). Someone told me it was tannic acid in oak leaves that cause the stain on cement. I do not know if that is true but I can tell you the oak leaf stains in driveway were there atleast two years and might still be... I moved so I don't really know.
Rege
Old 05-14-2009, 06:14 PM   #7
I use some pool chlorine and water mix but that isn't too good for vegetation and it seems to work fairly well but there is still a ghost image. I may do some googling for a better remedy; if I find anything I'll post it.
Old 05-15-2009, 07:08 AM   #8
Rewards Points: 1,016
Rent a good power washer - try it, see what's left (if anything) then go from there.
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
Pressure treated posts set in concrete? zubin6220 Building & Construction 19 08-13-2013 06:39 AM
How long should I wait to prime siding after pressure washing? bluefitness Painting 8 02-12-2009 11:37 PM
Pressure washing siding bluefitness Painting 11 02-04-2009 06:33 PM
