Pool Care Guide - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-07-2008, 01:56 PM   #16
Dude
JohnnySixString's Avatar
Originally Posted by sevver View Post
I know that the only way to dump CYA is to dump water. But it seemed that when my wife was taking care of the pool, it seemed like there was a cycle of using stabilized Cl, until there was an algae bloom, then it would go out of control until you "shocked" your pool with twice the dose for a few days, at which point things seemed to go back to normal again. So, I don't know that for sure, does the algae break down the stabilizer or doesn't it...? I will ask that question at TFP since this place is geared more towards beating things together.
I have since started the BBB method of pool care, and I have never had any problems. I have my TA at around 90, which makes my Ph stable at 7.3. I also just use the liquid shock from the pool store. It is 12.5 strength, and I don't leave it in direct sunlight, it is in the garage. The breakdown is exponential from the way I understand it. It loses its strength faster the higher that it is and slower the lower the percentage. CYA is necessary, not that you said that it wasn't, but it gives the Chlorine something to bond to so that the sun does not burn it off too fast.
My pool is only 8600 gallons, and I am SERIOUSLY considering a SWG, that would essentially free me up to go away on the weekend on occasion without needing to bother anyone.
Basically, check out TroubleFreePool.com, educate yourself, get a good test kit, and spend 5 minutes a day on water chemistry. Everyone will be amazed.
Exactly.
JohnnySixString is offline   Reply With Quote
Old 06-07-2008, 08:41 PM   #17
Underground Techie
sevver's Avatar
Here is the link discussing what happens to cyaneric acid; [http://www.poolforum.com/pf2/showthread.php?t=8605]
Chemgeek discusses it over at Poolforum. He references to this study on the matter [http://umbbd.msi.umn.edu/cya/cya_map.html]
Basically I was right in assuming the stabilizer gets used up by the algae. And basically otherwise it is correct to assume that stabilizer cannot be removed otherwise without drain and fill dilution.
**I hope this forum allows linking to other forums, I seem to remember that it doesn't.**
Just in case, here are the two links with spaces in them. Copy Paste, delete spaces, hit enter.
http://www.poolforum.com /pf2/showthread.php?t=8605
http://umbbd.msi.umn.edu /cya/cya_map.html
sevver is offline   Reply With Quote
Swimming Pool Converted To Fish Pond ghall79 General DIY Discussions 6 05-23-2008 11:11 AM
Moles unde pool liner...causing "craters" abacuslearns Landscaping & Lawn Care 1 10-27-2007 07:37 AM
Pool Wiring phinfan1266 Electrical 4 06-27-2006 02:31 PM
