Polymeric Sand On Paver Job - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-21-2013, 01:12 PM   #1
Polymeric Sand on paver Job
Hi!
We have had a contractor grade and set 1400 square feet of pavers, but we are finishing it by putting the polymeric sand in.
I just realized that one small piece of paver in the pattern is missing and wasn't cut prior to them leaving yesterday.
We are supposed to sand today, but there is no piece there. It needs to be cut and we dont have the right equipment.
Any suggestions?
HackHomeOwner is offline   Reply With Quote
Old 07-21-2013, 01:18 PM   #2
bbo
you can use a grinder, they are fairly cheap. harbor freight one I have just won't die ( and I'm waiting to get a new one .. haha)
bbo is offline   Reply With Quote
Old 07-21-2013, 01:20 PM   #3
Rewards Points: 226
have them cut a piece for you. in the mean time, do your sanding. just put a rag in the hole.
Fix'n it is online now   Reply With Quote
Old 07-21-2013, 01:26 PM   #4
I do plan on having them cut the piece, but they wont be back until Friday or so.
If I put a rag in the hole, do I leave that in when i water the sand or take it out?
Old 07-21-2013, 08:58 PM   #5
Rewards Points: 226
idk. can you wait to water it ?
Old 07-21-2013, 08:59 PM   #6
Rewards Points: 226
oh. round here, we like pictures.
Old 07-21-2013, 09:13 PM   #7
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 4,652
Probably best to water it on fresh planting, might add some root starter to help it take root....
Hacker... it really does not mater, put a rag in to keep your sand from spilling into the void while it sets.... then put your cut piece in and poly sand... and sprikle it.
Even if you don't.. you can chizel out poly sand witha butter knife.
No problem
Best
MTN REMODEL LLC is offline   Reply With Quote
Polymeric sand in paver walkway Andy54 Concrete, Stone & Masonry 3 08-31-2012 12:22 AM
Is PVC too brittle in cold for drain under a paver patio? BrandonC_1972 Landscaping & Lawn Care 1 07-20-2012 01:18 AM
Paver Sand and Blue/Grey Colored Bricks Curious123 General DIY Discussions 4 08-13-2009 09:22 PM
Paver Patio w/ Polymeric Sand Kyle Landscaping & Lawn Care 3 04-27-2009 07:55 PM
Paver install-hand tamper vs plate compactor bigboyjoel Landscaping & Lawn Care 9 07-23-2008 03:48 PM
