Pole Saws, Electric Or Battery - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-13-2013, 08:57 AM   #1
Rewards Points: 2,072
pole saws, electric or battery
I hate dragging a heavy electric cord around the yard, but I'm doubtful a lithium battery will last long enough to do all my trimming. I have a lot of trees and shrubs. Of course I don't have to do everything at once. I do love my Toro battery weed eater.
I'm researching pole saws. Almost decided on one that was recommended but am not happy with the reviews, such as the chain breaking. I hope not to go over $150.
any opinions? Thanks.
Startingover is offline   Reply With Quote
Old 09-13-2013, 09:09 AM   #2
Rewards Points: 13,300
Both not the best option, but if I had to choose I'd go with the electric one, more torque unlimited run time.
I mainly rehab 100 plus year old houses and often have to cut out old beams inside enclosed spaces so I tried using a battery operated chain saw. It was useless, 1/2 through it would die.
My cheapo Homelite electric still works fine after about 5 years.
There going to put the cheapest chain they can on a cheap home owner grade tool.
Just replace it with a better one.
Make sure your cutting from the top of the limb not the bottom to reduce binding, even then it's common at the angle your cutting at to have the chain bind stress the bar and blade.
Startingover (09-13-2013)
Old 09-13-2013, 09:15 AM   #3
PoleCat's Avatar
Rewards Points: 1,646
I am done with battery powered tools. The handy factor gets trumped by the limited power and endurance, and replacement battery costs are too high.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
Old 09-13-2013, 09:15 AM   #4
thanks Joe.
What kind of outdoor extension cord do I need. An electrician gave me an orange one yrs ago that was fat around and too heavy so I guess they come in different wire sizes.
The saw I'm looking at has a 10" chain. Does that mean it will cut 10" branches? One review said it was hard to find a replacement chain for 10".
It's mostly shrubs and maybe 3" branches that I need to cut. But I do have some bigger limbs 8" I'd cut if this saw could handle it.
Also: what kind of chain oil do I buy? Will I find a bottle labeled "chain oil" at the big box store?
Old 09-13-2013, 09:23 AM   #5
I would not use less then a 12 gauge cord. Any less and it causes a power loss and the motor will over heat.
I use all Yellow Jacket brand cords, there heavy duty and have a light built into the end of the cord to let me know if there's power.
10" would be the max it will cut, but with a light duty tool like that I'd be taking my time and letting the blade do the work.
Old 09-13-2013, 01:28 PM   #6
Guage of wire would also depend on length. I think I have a 100ft extension cord that is 10ga for heavy tools like this.
Check the rating of your saw (how many amps?). Extension cords are typically labeled for max current. Pick one that matches.
oberkc is offline   Reply With Quote
The Following User Says Thank You to oberkc For This Useful Post:
Old 09-13-2013, 03:31 PM   #7
chitownken's Avatar
Rewards Points: 510
Yes, you will find chain oil in the big box stores and most hardware stores (ACE) as well.
chitownken is offline   Reply With Quote
The Following User Says Thank You to chitownken For This Useful Post:
Old 09-13-2013, 03:41 PM   #8
I'll have to measure. I need to reach 100 ft, but I already have a 15' outside electric cord.
thanks.
There sure is a lot to know when you're using tools.
Electric to pole barn ddailey Electrical 11 04-24-2013 07:09 PM
Replacing single pole light switches with double pole bruce54 Electrical 43 04-15-2012 11:23 AM
Nailers - pneumatic vs. electric (battery) cellophane Tools 10 06-08-2010 04:42 PM
String trimmers - gas, corded electric, or battery electric - which one?? whataboutj Landscaping & Lawn Care 43 05-01-2010 10:25 AM
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 03:01 PM
