Plastic Under Lawn? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-18-2009, 11:19 PM   #1
Plastic under lawn?
Greetings, I am about to prep my front yard for sod but I need some advice. The area is completely gravel (pit run) with absolutely no soil in it. I have enough top soil for about 8 inches but a friend suggested to haul in clay for a base to hold the moisture. He thinks that the gravel underneath is a lawn watering nightmare.
Clay is a little hard to come by around here and I was wondering if a layer of plastic underneath the soil would be a good idea or not.
the carpenter is offline   Reply With Quote
Old 11-20-2009, 07:15 AM   #2
I'd say 'NOT' to the plastic. Your friend had a good suggestion. Go with the clay, then the top soil. Good luck!
Lali is offline   Reply With Quote
Old 11-21-2009, 08:58 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 334
Ayuh,... Either Clay or even dirt will act as a sponge to help hold water for the lawn,...
Plastic will Not do that or help in Any Way...
Bondo is online now   Reply With Quote
Old 11-21-2009, 10:32 PM   #4
Lawn went in about three months ago. Thanks for the speedy replies. We ended up going with the clay. The wifey never did like my plastic theory......every DIYer needs a good wife to keep him under control with any sort of wild idea.
Old 11-22-2009, 05:33 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
What is annoying is that they are usually right
Old 11-22-2009, 06:08 AM   #6
You're welcome...gimme a break, I just joined less than a month ago & noticed that nobody had responded to your 'dilemma'. Funny tho'; how once someone does reply, several follow!
Lay plastic between ground and concrete slab? Flt_Simulation Flooring 8 04-22-2012 06:56 AM
are the geese destroying my lawn? windowguy Landscaping & Lawn Care 17 04-16-2009 09:38 AM
Solar Charged Brushless Lawn Mower Educator Electrical 2 04-20-2008 01:43 PM
Why can't I grow a proper lawn? joeyboy Landscaping & Lawn Care 7 11-21-2007 12:36 PM
Help with SHOT lawn nsb318 Landscaping & Lawn Care 4 05-09-2007 11:10 PM
