Planting New Grass - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-14-2011, 10:18 AM   #1
planting new grass
i have a circle of sand that was used for a pool. what type of dirt should i use to cover it so that i may plant grass there?
good advice but not what i am looking for. what type of dirt do i need to cover the sand before planting grass seed.
tomdel is offline   Reply With Quote
Old 03-14-2011, 11:23 AM   #2
Rewards Points: 150
IF you have grass outside the circle and want to match it, then try to use the same dirt, otherwise it may always look different there and you'll see the circle. If not, well..maybe someone else can answer.
NancyNGA is offline   Reply With Quote
Old 03-14-2011, 11:37 AM   #3
Rewards Points: 120
As Nancy said, it is going to depend on the quality of your existing lawn. If you live in an urban area, with well manicured lawns, you will probably want to use a good quality top soil, which you can get from your local nursery. And, if you want to match the existing lawn as close as possible, dig out a small patch to take with you, so that they can tell you what you have now. If you live in a rural area, you might be able to simply watch for some "free dirt". First though, I would remove as much sand as possible, and would rototill the entire area, or trun it over with a shovel. I would think that this is essential, because water is heavy, and with a pool having sat on the area, it is not only compacted, but probaly sloped toward the center as well, and it is very likely that you could end up with a spongy area every time it rains, if it is not loosened.
Old 03-19-2011, 09:01 PM   #4
trying to find out what type of dirt to use to cover a plot of sand. not trying to match the exciting grass.
Old 03-21-2011, 01:03 PM   #5
Rewards Points: 45
The simplest answer has been stated: topsoil. You don't want to use garden soil or commercial potting soil or anything like that since it will have a completely different texture and qualities from your soil. Topsoil is readily available anywhere for delivery or pick up from a local nursery or landscape supplier. See if you can get native top soil that will be most like what you already have in your yard (as it can vary a great deal)
Plump is offline   Reply With Quote
Planting grass seed debrobin1 Landscaping & Lawn Care 2 03-04-2011 11:21 PM
Advice on Planting Grass Seed Around Oak Trees Shaun_in_NC Landscaping & Lawn Care 4 10-15-2010 06:24 PM
Planting Grass in Shade, Tree Pruning joetab24 Landscaping & Lawn Care 16 03-09-2010 04:32 AM
Planting grass after tilling existing lawn werc Landscaping & Lawn Care 1 05-22-2008 01:38 AM
grass planting johnny331 Landscaping & Lawn Care 6 06-01-2007 08:45 PM
