Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 05-11-2010, 02:24 PM   #1
k1080
Question
Placing pavers over existing concrete patio
Do I need to use mortar, or can I use only sand to redo my concrete patio? Also, we do have some cracks in the cement should they be repaired first?
k1080 is offline   Reply With Quote
Old 05-11-2010, 06:01 PM   #2
GardenConcepts's Avatar
You can epoxy the pavers to the perimeter of the concrete slab and use sand for the field. I've done this using 2 3/8" thick pavers for the field and 3 1/8" thick pavers for the perimeter. Your sand bed is the difference between the two thicknesses.
I would at least use a concrete caulk to fill the cracks.
Chris
GardenConcepts is offline   Reply With Quote
Old 05-12-2010, 07:03 AM   #3
k1080
Thank you very much for your information. This will be a fall project, as it is too hot now to do it. I will post photos.
Old 05-12-2010, 05:22 PM   #4
Hey Garden,
Do they need to drill holes for drainage?
I would be afraid that the glued perimeter would hold the water in like a basin on the concrete slab.
Especially during a heavy rain.
Just curious is all. I have no experience with pavers over concrete. It would save a ton of work though.
Bushman is offline   Reply With Quote
Old 05-12-2010, 07:55 PM   #5
Never had a problem with water- heavy rain will flow over top of the pavers. The epoxy only sits on the bottom of the perimeter course. I have one install from 6-7 years ago that is still good.
Chris
Old 05-13-2010, 12:15 AM   #6
Yes, please post pics. We don't always get to see the finished product.
Allison1888 is offline   Reply With Quote
Old 05-13-2010, 12:22 AM   #7
Concrete & Masonry
I'd agree with this as well. Although it may not seem ideal in theory, it seems to work very well in practice. I've done quite a few installations similar to this, but with a flexible adhesive on the perimeter vs. epoxy. All have held up well to the harsch winters we commonly see here. I've even dry-laid the brick infill before w/o issue, but I always use polymeric sand.
I should state though that I only do this on new concrete bases that I have installed myself, as I'm not willing to gamble on top of existing failing concrete that I dn't have any insight on.
jomama45 is offline   Reply With Quote
Old 08-12-2010, 08:11 PM   #8
If the overall quality of the concrete patio is still good, then there should be no problem using sand to fill in the middle of the paver area, polymeric sand to be exact. However, I don't have pics of your existing patio to make that judgement call for you.
MajesticPaving is offline   Reply With Quote
Tags
concrete cracks, patio, pavers
building porch over concrete slab patio lachase Building & Construction 1 05-03-2009 02:43 PM
Pavers and Concrete TinyT Landscaping & Lawn Care 2 03-24-2009 08:23 AM
Concrete Pavers and Stain terryhflyer Flooring 2 06-04-2008 05:59 PM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
