Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 07-02-2009, 02:19 AM   #1
Pipe Size
I am excited installing a sprinkler system for the first time. This will be a big challenge for me.
I have just started collecting data and already have a question, what size pipe I should use. Here is the data:
Water Meter Size: 5/8"
Service Line: 1" PVC
Water Pressure: 55 PSI
Water Flow: 8.6 GPM
Is this enough to figure out what size pipe I should use? I am not sure if I should use 3/4" or 1". My yard has a very minor slope. I would appreciate anyone who has had experience with this.
Thanks,
Pochi
pochi is offline   Reply With Quote
Old 07-02-2009, 10:37 AM   #2
Licensed P.E./Home Insp
Aggie67's Avatar
Pipe Size
Try this:
http://www.irrigationtutorials.com/sprinkler00.htm
I actually used it while waiting for a design book to come in the mail.
Also, if you're on city water, make sure you install a backflow preventer. They (water utilities) are extremely cautious of contamination issues.
The plumbing inspector should be able to point you in the right direction on what type of preventer they require (gapped, not gapped, double, etc).
Aggie67 is offline   Reply With Quote
Old 07-04-2009, 04:13 PM   #3
Pipe Size
Thanks Aggie.
I went to the irrigation tutorial link and found answers to many questions I had. Excellent information from an expert!
Pochi
How to Reduce pipe size wrv369 Plumbing 5 05-22-2012 01:33 AM
Need Help! Non-standard pipe size?? dc4nomore Plumbing 18 05-03-2009 10:59 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
Identifying size of Black Iron Pipe jamiedolan Plumbing 2 10-06-2008 01:39 AM
Pipe size for hose bibb BigJimmy Plumbing 1 03-12-2007 02:53 PM
