Pipe Fence Removal - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 01-09-2010, 09:54 AM   #1
Pipe Fence Removal
We're considering purchasing some property that has considerable amounts of pipe fence, to include animal pens and a hodge-podge of perimeter fence. While we want to maintain some of it, a lot of it looks junky and we want to get rid of what we won't use. We have some experience in removing steel fence posts, but not this extensive.
My question: What is the best way to remove welded pipe fence? At this point I'm not sure if the posts are anchored in concrete or not.
Should we have a professional remove it? Not sure how much that would cost.
Can we do it ourselves with the right rental equipment?
Any advice would be greatful.
alwilson is offline   Reply With Quote
Old 01-09-2010, 09:56 AM   #2
bobcat and chain, if looking to reuse get auger attatchment with bobcat
Old 01-09-2010, 10:08 AM   #3
The bobcat idea would be the fastest and easiest. Also check out renting a walk behind unit such as a dingo using slings to pull out the posts.
Chevy85 is offline   Reply With Quote
Old 01-09-2010, 10:27 AM   #4
I only had 9 posts to pull out
Some came out just by moving back & forth
Some the concrete came apart with 1 shot from a sledge hammer
One was a lot of concrete & was a PIA
By the pool area, no room for a bobcat...not that I would have rented one for 1 post
Depends upon your soil, if in concrete & how much
Old 01-09-2010, 05:46 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,006
Ayuh,... Depending on the terrain,..
A pickup truck with a trailerhitch,+ a chain will remove alotta fence....
Old 01-09-2010, 06:18 PM   #6
do it right and the truck will take all at once
Old 01-10-2010, 02:20 PM   #7
thanks...
bobcat, slings, etc...
Thanks for the ideas. Nice to know there's a diy option.
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
Painting Pipe fence zubin6220 Painting 13 12-06-2010 10:54 PM
Largest Crown Molding Cut on DeWalt 716 Klawman Carpentry 8 11-14-2009 08:05 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 05:40 PM
Pipe Fence Painted NOW Flaking~HELP! jackieO Painting 2 06-01-2008 08:33 AM
