Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 07-10-2011, 02:10 PM   #1
Steve S's Avatar
Pilot Jet question.
My lawn mower has been surging. I did a pretty thorough job cleaning out the carb earlier this year. When I took out the pilot jet I stuck a fine wire down the hole and could see it in the cross hole so I assumed it was clear.
Now that it's surging I removed the pilot jet again and I can get a fine wire down the hole, but a slightly thicker one only goes in about 2mm and then stops. So does the hole have a shoulder inside of it, or does that sound like blockage (see pic below)? I soaked it for about 30 minutes in carb fluid but that didn't work.
Thanks in advance.
Steve S
Steve S is offline   Reply With Quote
Older Carrier Pilot Burner Problem cliffkot HVAC 23 04-29-2011 06:58 PM
Heil Furnace Pilot Light Not Igniting shwank HVAC 13 10-07-2010 07:41 AM
Tempstar pilot not lighting after draft inducer replacement Kdavid HVAC 53 03-27-2009 03:10 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
pilot light reignition on older williams model Unregistered HVAC 1 02-17-2004 10:26 PM
