Pex Outside - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-16-2009, 04:14 PM   #1
pex outside
can i use pex outside, like to put water spouts in different locations??
marin001 is offline   Reply With Quote
Old 03-16-2009, 05:21 PM   #2
Don't know it all, yet!
Just to get on the same page, do you mean spigots/hose bibs or irrigation heads?
Don't really see why you couldn't though either way.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 03-16-2009, 06:18 PM   #3
the Musigician
DangerMouse's Avatar
if you mean underground, pex crimp fittings are not rated for burial. If you need to bury them, you'll need to use Sharkbites.
DM
Old 03-18-2009, 05:20 PM   #4
both of you guys are correct in your assumptions, and yes i will be using sharkbites they cost more but the time you save is unbelievable and your able to use them again and again if need be. thanks for the replies
Old 03-18-2009, 06:51 PM   #5
DM
Now that's teamwork!
Old 03-20-2009, 03:59 PM   #6
Also, PEX cannot be exposed to sunlight/UV.
stubits is offline   Reply With Quote
