Permeable Retention Product - 2 B Used 4 Pea Gravel / Decorative Rock - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 01-20-2006, 10:17 PM   #1
I'm just stirring the:
CGofMP's Avatar
Okay this may seem silly BUT....
I need to separate pea gravel or decorative crushed rock from different parts of the yard... BUT I do not want to interfere with the drainage. If I use the plastic lawn edging, bender board, or other products I've seen used for this I will make a little dam that I do not want.
So... I need to find some way of holding the rocks back but at the same time not stop the water from going from on section to the other.
It also needs to be something that one can step on and not break it.
Any ideas?
CGofMP is offline   Reply With Quote
Old 01-20-2006, 10:29 PM   #2
Rewards Points: 150
how tall does it need to be?
pipeguy is offline   Reply With Quote
Old 01-20-2006, 10:33 PM   #3
CGofMP's Avatar
Just high enough to hold back pathway rock for a residential traffic path.
I'm guessing 2 inches?
could be less if I used pea and a bit more if I used larger rocks.
Old 01-21-2006, 06:29 PM   #4
Contractor
How about sailored brick with a gap between each? Concrete pavers could be used in the same way. Deco stones?
Teetorbilt is offline   Reply With Quote
Old 01-23-2006, 05:10 PM   #5
2nd half
Maybe Belgium Blocks.
jmic is offline   Reply With Quote
