Perforated Corrugated Pipe - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-21-2016, 08:37 AM   #1
Rewards Points: 4
Perforated corrugated pipe
My downspouts drain into a perforated pipe that runs under the width of my sidewalk 4' and into my yard about 6 feet past sidewalk.
The sidewalk is new, I paid no attention when the concrete was poured over these pipes, until now. I figured it was just corrugated pipe, but upon further inspection the corrugated was perforated.
Should I be concerned about the perforated pipe under my sidewalk?
Can I insert a smaller piece of pvc pipe into that corrugated and run it onto my gutter and connected it with the right adapters?
Indiapaleale is offline   Reply With Quote
Old 03-21-2016, 10:57 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,368
Re: Perforated corrugated pipe
Naw, No worries,... Water will follow the path of least resistance,...
Which is down the pipe to daylight,....
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
jlhaslip (03-23-2016)
Old 04-01-2016, 01:11 AM   #3
I might be more concerned with the fact that, if I understand correctly, the corrugated pipe is also perforated where it connects with your gutter's downspout. If that's extremely close to your foundation, I'd want to make sure it's not seeping out too much within the first few feet.
Of course, it sort of depends on the style of the perforations in the corrugated pipe. Are they the ~0.5 inch holes, usually in two or three rows facing downward? Or the tiny little slits that are placed all around the pipe?
As for the sidewalk, I'm assuming you're just concerned with the soil getting saturated and causing the sidewalk to crack?
a powe is offline   Reply With Quote
Old 04-01-2016, 04:44 AM   #4
Rewards Points: 4
They are the tiny slits and yes my main concern is the concrete cracking.
Continuous Current on Water Pipe terps530 Electrical 263 04-11-2015 12:08 AM
Need advice on rusted pipe problem silencer Plumbing 16 12-02-2012 08:59 AM
PVC or CPVC pipe cement steve3847 Plumbing 7 11-17-2012 05:50 PM
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
