-   -   Pebble Overlay (over existing concrete patio) (http://www.diychatroom.com/f16/pebble-overlay-over-existing-concrete-patio-53897/)
febbaj 09-27-2009 09:35 AM
On a recent Yard Crashers show, the host (Ahmed), showed a pebble mixture that gets combined with some sort of epoxy and gets troweled over existing concrete. Looks Great? Any idea where I can get this product?
Thanks.
Quickdraw 09-27-2009 10:13 AM
Thanks.
You should try http://www.diynetwork.com/ - the shows keep hawking this site but Ive not found any of the "more detail" they urge you find at the site. The two times I've looked there wasn't even as much info as the show provided.
user1007 09-28-2009 01:10 PM
Is this more fine than you wanted? It is a good system but a bit pricey.
http://www.abatron.com/cms/buildinga...colorgrit.html
febbaj 10-03-2009 01:40 PM
Pebble Overlay
Thanks for the response. Yeah, the product featured on the show was a bit coarser. The mixture consisted of pea size pebbles mixed with a clear epoxy. It was applied with a trowel and the finish looked terrific.
PrettyByrd 10-11-2009 09:39 AM
I was wondering the same thing - husband pointed me in the right direction, "PebbleCrete". You can also look at your local HD or other home repair stores, usually in the concrete mix aisle.
Lewiscj 10-16-2009 10:12 PM
Pebble Stone
Here you go - it's Pebble Stone and they're located in Las Vegas. Looks like a great product. 100 sf minimum is $1399.
http://www.pebblestonecoatings.com/
ArcyPSC 10-20-2009 11:39 AM
Incorrect Quote
I'm sorry to inform you, however that quote is for an entirely different product. At that price it would be $13.99 per square foot. The stone at this company is only $6.99 per square foot. Also keep in mind that most states require that you MUST be an experienced installer of this product; due to the possible exposure to these potentially harmful chemicals.:nuke: Epoxy is a very sensitive product to work with. Once combining A & B you have a very limited pot life for this product. I would not recomend ANYONE to attempt to install it themselves.:eek: You're better off hiring an experienced installer. If you are looking for an installer go to www.google.com, type in your city and state, along with EPOXY ROCK; and it SHOULD give you the closest installer.:)
Summers@TheLake 10-25-2009 06:48 PM
I had the epoxy pebble installed on some of my concrete walls and sidewalks when I put in a pool 2 years ago. GREAT product and zero problems with it. Install cost was right at $4.00 a sf. Others in my area have used this product and also good results.
I am in the process of rebuilding my exterior decks and can't decide between porcelian tile or epoxy stone.
sashaeffer 04-15-2010 04:39 PM
After seeing the same show I was also curious. I went to HD, LOWES and asked about it. After chasing around the only epoxy they carry comes in smaller containers (pint). I did some research and found this company.
http://www.jgreer.com/rock-pebble-deck.htm The process is the same as a local company here near Omaha called Lusterstone. From what I saw on Lusterstones website the process is exactly the same, and I have a relitive that has it on her driveway and it has held up really well in Nebraska winters.
There is a significant savings in doing it yourself VS Lusterstone if you want to take the time to do it.
Scott/Omaha
Buster13h 04-22-2010 12:49 PM
another choice
here is a link for yet another dealer that covers southern CA, AZ and Nevada
https://www.pebblestoneflooringsystems.com
I searched forever on HGTV and DIY sites to no avail so I googled pebble stone overlay on patios and found this site
Grofica 04-26-2010 09:59 AM
thats awesome!
donnhello 08-22-2010 01:44 PM
Thanks.
Have 34 years exp in expoxy stone installation as well as cleaning and REEXPOXY coating exsisting Decks.
If I can be of help Please call: Ron (936) 232-5008
Thank you,
KelBelle 06-04-2011 12:09 PM
Here you go: http://www.diynetwork.com/how-to/lay...tio/index.html
CherylB 06-18-2011 03:08 PM
I was also interested in the pebble overlay, does anyone know how it stands up to cold weather? (snow, Ice)..
Bud Cline 06-18-2011 04:22 PM
There is more than one brand of that type of epoxy/stone product. In the southern climates of the country it works okay. In the northern climates it fails miserably. I was trained and certified in the installation of one of the better-known products at the time and they are now out of business.
Freeze/thaw is not very friendly to the product and none of them tell you that the product must be revitalized and re-coated annually with an expensive sun screen to block against sun damage. They also don't tell you that the product will turn yellow (called ambering) over a short period of time.
If you live in the south and have deep pockets then try it. I would advise against it.:)
