Paving Stones And Drainage - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-28-2011, 05:51 PM   #1
HandyMan Engineer
Paving Stones and drainage
Just moved into a new house and I'm planning a few renovations but the first issue is the the water seeping into the basement in one corner (coming between wall and slab). This was a known fact and refected in the price. Now just need to solve the problem. I think I have most of the options figured out (clean/replace external weeping tile; add internal weeping tile to sump, repair grading), but one possible issue is nagging at me.
The situation:
The yard slopes back to front. I have some grading issues on the side as the back fill has settled and needs to be redone, but at the back corner of the house is a 14'x14' stone paver patio. It's slope isn't great and I will also pull this up and redo but my concern is that past this is the swale where all my water is supposed to drain to, to bring the water around the house and to the front. It's grass and with not much slope so it does pool. So is the water that is sitting at the edge of the patio seeping through my patio base of sand and rock crush to the foundation wall adding to the issue. is there anything to add as a barrier to this water?
Any input would be appreciated.
sendres is offline   Reply With Quote
Old 05-02-2011, 04:24 PM   #2
HandyMan Engineer
Some Good news
I've stuck the hose of the shop vac in the corner where the water is coming up and it has stopped everything from getting wetter. Over the weekend it has gone from 16 litres per day to about 5.
Old 05-02-2011, 09:15 PM   #3
Rewards Points: 1,418
You can't block the water. You have to redirect the water, for example by regrading the land so the swale is futher away from the patio and the foundation.
Drainage problem - need advice gruntman Landscaping & Lawn Care 15 07-24-2011 10:19 PM
Improve Drainage for clay around base of house kango86 Landscaping & Lawn Care 5 03-28-2011 03:48 PM
Retaining Wall - Stones and Support? revkev1952 Landscaping & Lawn Care 3 08-09-2010 03:02 PM
Drainage issue, HELP!!!! Rskillz Landscaping & Lawn Care 1 04-18-2009 09:35 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 04:29 PM
