Paving On Existing Flagstones - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-11-2009, 12:10 PM   #1
Paving on existing flagstones
I have flagstones patio built in my back yard. These are scattered all over the yard. I am planning to replace these with patio slabs (to make it tidy)
Would it be advisable to remove flag stones and then put gravel.
or Gravel over the flagstone should work if properly compacted.
Removing flagstones will end up high costs and time.
leafnation5 is offline   Reply With Quote
Old 06-13-2009, 12:53 PM   #2
Rewards Points: 5,336
You would remove the flagstones to do it correctly.
Ron
Old 06-13-2009, 01:00 PM   #3
Many of my flagstones were loose on my back patio
Removing them repvent wate rfrom getting under them & causing problems with freezing & thawing
What are you going to "pave" with? Concrete? Pavers?
Old 06-17-2009, 10:10 AM   #4
I thought about that and it would appropriate to remove them as I am spending lot of money on Triple H slabs.
Another question, what would be advisable to use HPB or gravel? Do I need to put screening on HPB?
Replacement Aluminium Window - Reusing existing sill flashing? GrantJohnson Building & Construction 4 02-10-2010 10:27 AM
New Roof and Insulation over Existing Roof MitchellScott Roofing/Siding 1 05-03-2009 08:24 AM
cutting existing tile rockybgood Flooring 7 12-03-2008 04:51 PM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 11:16 AM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
