Pavers Over Concrete & Grass? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-15-2012, 01:31 PM   #1
Question
Pavers over concrete & grass?
I have a small concrete patio on the back of my house, that is 3/4 of the way covered up with a large deck that built over top. There is only about 4 feet or so of concrete stick out from under the deck, but we cannot get up the concrete without pullling up the deck, or risk damaging it.
My question is, is it possible to do a paver patio over top of the existing concrete (I know the answer to this is yes) but ALSO extend it out in the yard (over the grass) as well? Therefore, the pavers would be ontop of the concrete and extend out into the backyard creating a larger patio.
I'm not sure how to do this and make it level? Help!
katkins0027 is offline   Reply With Quote
Old 05-17-2012, 12:52 PM   #2
no advice at all??
Old 05-18-2012, 09:37 PM   #3
Rewards Points: 264
I think you can do this, you will need to ensure a proper base is prepared in the yard area.
You might want to search and post this in the concrete, stone, and masonry forum. Those guys should have some concrete advice...
7echo is offline   Reply With Quote
The Following User Says Thank You to 7echo For This Useful Post:
katkins0027 (05-30-2012)
Thinking about making concrete pavers - a few questions Luis C. Building & Construction 16 06-10-2011 05:45 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Grass between Pavers haveyouseen Landscaping & Lawn Care 6 10-10-2010 05:38 PM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
Pavers vs concrete jizzle Building & Construction 9 04-15-2009 08:20 AM
