Pavers In FL - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 12-29-2011, 11:58 AM   #1
Pavers in FL
Hi,
I am interested in laying some pavers down in my backyard for a patio (16'x8'). Should I layer @4" of gravel first before the paver sand? A gentelman I just spoke with mentioned that most folks in FL just use 2" of sand and no gravel. My concern is shifting pavers. Thanks in advance for any advice...
digajam is offline   Reply With Quote
Old 12-29-2011, 01:28 PM   #2
concretemasonry's Avatar
Rewards Points: 2,578
I assume what you call "paver sand" is really the sand used for the 1" setting bed. the maximum thickness is about 1" and should be uniform. Normally concrete sand is used.
For the surface and interlocking sand, a slightly finer sand is often used (masonry sand) is used and vibrated into the tight joints when the paver surface is evened out with a plate vibrator.
The thickness of the gravel base below the setting bed of sand depends on the stability of the sub base (usually natural soil). For drainage (if desired) of the patio, the surface of the gravel base should be sloped to be able to maintain a uniform 1" setting bed thickness.
Dick
concretemasonry is offline   Reply With Quote
Old 12-29-2011, 01:54 PM   #3
Thx...I will definitely use @1-2" of gravel (or marl) prior to laying the base sand. I dont have a plate vibrator so I just plan to sweep masonary sand into the joints, water and repeat for a few weeks. I'll post pics here in a few weeks once completed.
Old 12-29-2011, 01:56 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You can rent a plate vibrator and should use one.
XXX
Old 12-29-2011, 03:36 PM   #5
Is the plate compactor used only once after pavers are down, or should i use it first to compact the soil prior to shell layer?
Old 12-29-2011, 04:24 PM   #6
It is better to rent it when you are ready, then use it to compact and smooth base and then to draw the fine sand up and level the surface.
For a small 8x16 patio, you may do everything in one day if you are organized and not too fussy about setting the pavers (just set them quickly and tight). the final vibration is what makes things right.
Some patterns (like angular herring bone and others) take more time.
Dick
The Following User Says Thank You to concretemasonry For This Useful Post:
Bud Cline (12-29-2011)
Old 12-29-2011, 07:55 PM   #7
OK...Thx so much for all of your time...I'll post pics with results
Small Pavers vs Patio Blocks - Installation Difference snowfiend131 Landscaping & Lawn Care 7 04-17-2012 04:33 AM
concrete under pavers around pool deck , pavers go to edge of pool doggie44 Landscaping & Lawn Care 0 02-27-2011 11:40 AM
Water Seepage Under Pavers To Joist/Sill Plate BigNick183 Building & Construction 12 09-10-2010 05:49 PM
Pavers over a concrete sidewalk Beckerad Flooring 3 07-20-2010 09:59 PM
Brick pavers on driveway ???? sflamedic General DIY Discussions 2 04-21-2008 12:12 PM
