Paver Walkway, Gas Meter In The Way - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-30-2011, 05:55 PM   #1
Paver walkway, gas meter in the way
Check out the picture so you can reference what I'm trying to say.
I've already dug out the rocks and marked where my walkway is going however the gas meter is right in the mix of it all. I was thinking of coming straight from the edge of the gate up to the gas meter then just go around the pipe that goes into the ground then resume my normal line. Any suggestions or am I thinking clearly?
I did a quick MSpaint job to further indicate the lines of the walkway and the red will represent where the pavers will go around the pipe.
Cheers,
Ken
ken_ is offline   Reply With Quote
Old 07-30-2011, 06:29 PM   #2
DIY staff
Rewards Points: 7,174
Looks like your best choice--What other choice do you have?
Old 07-30-2011, 06:40 PM   #3
NACE Coating Inspector
mustangmike3789's Avatar
i agree. i would sleeve around that pipe to avoid bricks moving against it.
mustangmike3789 is offline   Reply With Quote
Old 07-30-2011, 10:58 PM   #4
Rewards Points: 372
Plastic pipe would work fine for a sleeve. You should be able to cut the sleeve vertically and then spread the sleeve around the gas pipe.
fireguy is offline   Reply With Quote
Meter Main problem. right-sided meter? acerunner Electrical 6 07-23-2011 12:41 PM
Height of meter box Arky217 Electrical 4 05-23-2011 10:56 AM
Installing stone paver walkway lkitchings Landscaping & Lawn Care 9 02-15-2011 09:11 AM
Possible Defective or Incorrect Electrical Meter? MorganB Electrical 10 01-18-2011 09:51 AM
Water meter aggravations Ultrarunner2017 Plumbing 8 03-21-2009 06:53 AM
