Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 09-16-2012, 10:12 PM   #1
Paver sand
Building a 20*20 patio dug out and put crush run compacted and put in gray concrete sand but ended up using 2-2/12 inches of sand screeted out laid pavers, seen online use one inch of sand pavers are Level with driveway. How much will these settle with that much sand should I still use plate compacter. No cars on this just foot traffic any suggestions.
walker45 is offline   Reply With Quote
Old 09-16-2012, 10:34 PM   #2
concretemasonry's Avatar
Paver sand
With the excessive thickness (2-1/2") instead of the recommended 1", the pavers can "float" and suffer differential settlement or rocking due to moisture under the pavement. Polymeric sand will not be a long term help since the moisture can come from the base or from the side.
The setting bed sand should be a screeded and not compacted uniform and a uniform 1" thickness. Any drainage (if desired) should be taken care of of with surface contours of the compacted base, but setting bed must be a uniform thickness.
These are normal installation for all interlocking concrete pavers (not the larger (12" or more wide or long) stepping stones that are of highly variable properties and strength with no standards, while the interlocking concrete pavers are much stronger (over 8000 psi) and how much you deviate with the installation is up to you.
Dick
concretemasonry is offline   Reply With Quote
Paver Joint Sand question: why is my sand so easily washed out? htabbas Concrete, Stone & Masonry 1 06-24-2012 08:04 AM
leveling sand question in DIY paver project htabbas Concrete, Stone & Masonry 1 05-08-2012 07:51 PM
finishing paver patio - what sand? H.O.P. Landscaping & Lawn Care 2 07-20-2011 03:00 PM
Paver Sand and Blue/Grey Colored Bricks Curious123 General Discussion 4 08-13-2009 09:22 PM
Paver Patio w/ Polymeric Sand Kyle Landscaping & Lawn Care 3 04-27-2009 07:55 PM
