-   -   Paver sand (http://www.diychatroom.com/f16/paver-sand-157020/)
walker45 09-16-2012 09:12 PM
Paver sand
Building a 20*20 patio dug out and put crush run compacted and put in gray concrete sand but ended up using 2-2/12 inches of sand screeted out laid pavers, seen online use one inch of sand pavers are Level with driveway. How much will these settle with that much sand should I still use plate compacter. No cars on this just foot traffic any suggestions.
concretemasonry 09-16-2012 09:34 PM
With the excessive thickness (2-1/2") instead of the recommended 1", the pavers can "float" and suffer differential settlement or rocking due to moisture under the pavement. Polymeric sand will not be a long term help since the moisture can come from the base or from the side.
The setting bed sand should be a screeded and not compacted uniform and a uniform 1" thickness. Any drainage (if desired) should be taken care of of with surface contours of the compacted base, but setting bed must be a uniform thickness.
These are normal installation for all interlocking concrete pavers (not the larger (12" or more wide or long) stepping stones that are of highly variable properties and strength with no standards, while the interlocking concrete pavers are much stronger (over 8000 psi) and how much you deviate with the installation is up to you.
Dick
