Paver Patio For Raised Foundation House? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-06-2010, 01:31 PM   #1
Rewards Points: 152
Paver patio for raised foundation house?
I was thinking of putting in a paver patio but the door from the back of the house is about 3.5 feet from the ground.
I do not wait to raise the entire patio since I want to be able to walk off the edge into the lawn.
So I guess I need some sort of steps going down to the patio 3.5' below.
Like this:
What is the best way to construct steps? Do you pour concrete steps then paver over that? Or is there some other way to do this.
THanks!
sandyman720 is offline   Reply With Quote
Old 05-06-2010, 06:06 PM   #2
GardenConcepts's Avatar
Rewards Points: 150
You could do poured concrete with pavers adhered to the concrete, or you could just use segmental retaining wall blocks for the steps.
The easiest way to build what you are looking for is a deck-style landing leading down to the paver patio. This also makes it easier to walk out the back door without having to immediately step down- much more comfortable to walk out the door to a level landing and then steps down. By going this route, you also avoid the 'heavy' look of a masonry cube stacked against the house.
GardenConcepts is offline   Reply With Quote
Pier and Beam foundation, 1925 house NewOldHomeOwner Building & Construction 8 01-30-2010 12:51 PM
Paver Patio w/ Polymeric Sand Kyle Landscaping & Lawn Care 3 04-27-2009 07:55 PM
Paver Patio Install ddave23 Landscaping & Lawn Care 2 06-20-2008 09:52 AM
Flagstone patio vs. Foundation Cangirl Building & Construction 2 06-19-2008 06:42 PM
cracked foundation on a new built house wilddngy Building & Construction 2 05-06-2006 10:56 AM
